flat painting questions
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
im going to be painting my bike flat black ive also been thinking about doing it to my camaro to but i havnt been able to find many good instructions on how to do it the proper way can anybody explain it to me or maybe tell me a book that would lead me in the right direction thanks
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Considering that most people prefer Shiny things... I would think the procedures and the steps involved are the same as a gloss paint. Usually flats are a little easier because you do not need to worry about dust & dirt...
There was a Flat black 2nd Gen Camaro across the street where I work (about 10 years ago) I always thought it looked like it was in primer...
I imagine it would be good for dodging Police lasers though
John
John
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
step 1: Sand car
step 2: Go to autozone/advance auto and buy flat black spray cans
step 3: Spray away(this the fun part!!)
step 5: Watch paint dry
step 6: Stand back, and admire
Thats what I did on my old camaro, and it didn't look half bad, but would I do it again hell yes
I believe there is something called a "flattening agent" which you can add to any paint to give it a dull finish. Beyond that, I think you can order flat black paint... I don't believe clear coat is required.
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
check this out
HOK Paint Home Page
see speciality products flattening agent you add to your clear coat...
now even easier one. same site click on kustomz shop look at the flatened paint single stage ready to go just add the catalist and mix super good and spray great stuff good price. they also have flattened clear if you want a trick color with that same 30% flat.
jeff
HOK Paint Home Page
jeff
Car: 82 z28
Transmission: TH350
thanks for all the great replies that iroc looks awesome i dunno what it is about flat black but i love it
It would probably depend on the brand of paint, but I know SOME base coats are flat when you spray them, when you clear coat it then it becomes gloss. I believe it helps with adhesion as flat paint is porus, much like primer...
John
John
I know that the primer is porous, and needs to be painted But I have never seen base color coat being porous... I do know that you can put a sealer coat between the primer and color coat to help eliminate primer shrinkage...
John
John
Engine: 305 tpi LB9
the only right way is to clear it, plain base or sealer is not deisgned to withstand uv rays water and the like we run into with a car. if you dont use a clear it will fade so fast in the sun your work would be a waste. flattened clear or the flatz single stage will last just like any other paint job
jeff
jeff
