Sain Finish
Old Nov 3, 2006 | 02:23 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Sain Finish
I'm thinking about doing a black primer/satin finish on my car. Is there a paint for that besides primer?
How do you protect a finish like that? Clearly, you can't wax it, and my car sits outside.
There's a guy at work who has his car in black primer. He said it gets shiny in spots and wears out on the creases, so he has to reshoot it every fear or so. Is there a satin paint available that won't wear out like that?
Old Nov 3, 2006 | 02:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you can just smear ATF on your black primer paint job
I think they make a "flat black" paint you can use. Look into the same brand of paint as your primer and whatnot, and see if they have a flat black. Think of school bus hoods, and things like that.
Old Nov 3, 2006 | 04:57 PM
chevylover5's Avatar
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
word of advise! it looks cool but it a real s.o.b. to maintain. i dont have ne good pix of mine, but it fades in spots and is just a biotch to spray evenly
Old Nov 3, 2006 | 07:46 PM
Jza's Avatar
Jza
My VRSCDX has what they call "denim black" paint with "vivid black" racing stripes. The denim black is basically a satin black color, but it's smooth and easy to maintain, and so far doesn't seem to get shiny or worn out on the high-traffic spots. You could probably look around for something by that name "denim". I've seen a couple done in "denim blue" and man they just looked awesome. It's also obvious that it's not primer, whereas a primer job looks exactly like just that. Primer.
I know they make "flatteners" for paint, also.
Old Nov 4, 2006 | 04:59 AM
Engine: L03 305 TBI
do you have any pics?
Old Nov 5, 2006 | 02:57 PM
Jza's Avatar
Jza
Phone pic, so quality isn't great..
Damn.... Google doesn't mess around. I searched for "denim black" and this post came up and it's only a day old. lol
Old Nov 6, 2006 | 07:40 PM
IROCKnIROC's Avatar
dupont has a new line of paint out that called hot hues and ther's a satin black that they call hot rod black, it's a single stage enamel so it is alot more durable than a primer or like a trim black, and it actually seals the metal unlike primers wich is very pores
Old Nov 6, 2006 | 08:21 PM
Engine: L03 305 TBI
Cool, thanks for the info
Old Nov 8, 2006 | 11:30 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
For flat black, simply get military type flat black, in spray cans. They're used for touchups on Hummers etc
Old Nov 8, 2006 | 11:57 AM
Engine: L03 305 TBI
I think that might be cool for small parts, but I don't think you're going to be able to get any kind of an even finish out of a spray can
SRKLEGIN
Oct 29, 2015 06:38 PM
91 SrS
Oct 7, 2015 04:32 PM
loud91rs
Oct 5, 2015 10:05 PM
James Sutton
Sep 23, 2015 01:56 PM
Linson
Sep 21, 2015 01:08 PM
