Aftermarket Fog Lights...
Old Nov 16, 2006 | 10:42 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
I have a 1990 RS, and it has the crappy RS grill, soon to be removed...
Now to the chase. i want to install some fog lights, i dont need/really want stock fogs, but which ones fit the easiest? I've seen the ones at autozone, but their bracet deign requires constant adjustment... I want a permanent solution....
Old Nov 16, 2006 | 01:30 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
I got mine for 5 bucks, I believe they're the same kinda cheapos they carry at Walmart and Autozone, you can get them for 5 at HarborFreight. Constant adjustment ? Yeah mine aren't 100 percent perfectly aligned, but neither are my headlights *L*
Old Nov 16, 2006 | 11:11 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
ok basically what i want is a bolt on mount, that will stay mounted...
Old Nov 17, 2006 | 12:07 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
so which ever ones you buy, drill a hole and mount it.
Old Nov 17, 2006 | 12:35 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
I got underneath the car, can't remember whether I drilled holes fromt scratch or if I simply enlarged original holes, either way, that's how I mounted my fog lights.
Old Nov 17, 2006 | 10:13 AM
turbochargedrs's Avatar
Car: Fire Red 89 RS
Engine: 2.8L :(
Transmission: 700r4 auto
If you really want stocks so badly then go to the junk yard and pick up a set of stocks and an iroc grill. If you want a different look or want to take your car to shows on ebay you can get lights that have the BMW style halo around them and actually pep boys sells halo fogs but they are round from pep boys and I dont know how that'll look on the square third gens.
Old Nov 17, 2006 | 12:32 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
it not that i want stock, thats definately what i dont want. I want a mounting bracket thats permanent kinda sorta. The way in which the autozone and walmart ones mount is with 2 bolts and a lock washer, and over a bump they will move and come out of adjustment...
Got any pictures of your walmart fog lights?
Old Dec 5, 2006 | 05:35 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i have a bunch on my cardomain site. and yes the mounting thing is somewhat of a hassle but i fixed that problem with a thick stock style bracket i can get you pics of that as well but it wont do you any good b/c i dont know what kind of car or truck the brackets came off of.
Old Dec 5, 2006 | 08:33 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Just get stock ones, they're permanent and you can get them fairly cheap on eBay now. The Wal-Mart cheapos are just that, cheap. I had some on the first Z28 grill I bought and not only did I have to drill huge holes in the grill but they didn't look really good and all the screws rusted in a few months. I got the real deal now and never looked back.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
