Removing weatherstripping
Old Nov 26, 2006 | 01:14 PM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
Does anyone know how to remove the weatherstripping that is ATTACHED to the t-top? I need to get to the screws underneath the weatherstripping and it's glued on the t-top. I dont want to tear it so I can reuse it. I thought about maybe trying to heat it but I am not sure if that will work. I am trying to replace the rubber strip that runs underneath the weatherstripping. Thanks in advance!!!
Old Nov 26, 2006 | 01:41 PM
crowebuilt's Avatar
I dont think that it can be done, but if you do please post a how to.
Old Nov 27, 2006 | 03:16 PM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
anyone????????
Old Nov 27, 2006 | 03:25 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
I assume you're talking about the weatherstripping on the glass top? It should'nt be glued on unless it's been replaced before. When you remove the trim panel from the glass you will see two screws holding the tabs for the weatherstripping into slots on the channel - remove them. Carefully pry the outside edge of the weatherstrip out of the channel and the rest should be evident.
If it is glued, go ahead and try the heat to soften it up.
Old Nov 27, 2006 | 03:47 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Try heat, or weatherstrip release agent or both.
Gasket remover will also remove the glue but be very careful because it will also remove your paint.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
