trans am tail lights?
Old Nov 26, 2006 | 09:28 PM
Pontiackid's Avatar
Car: trans am ws6
Engine: something special :)
Axle/Gears: 4.10 posi
hi i dont know if this goes here. anyways i got 85-92 trans am light. right now i have the stock 85-92 base ones in my 91 bird right now. my qustion is, will these lights bolt right up in, or do i need to switch the center piece out? thanks im also looking for a passenger side one, anyone have one or interested in trading for my stock lights?
thanks
Old Nov 26, 2006 | 10:48 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
If you have the 85-90 TA taillights, your going to need to use the center piece from it to look right, if you have the 91-92 TA taillights, they dont use a center piece.
Old Nov 27, 2006 | 02:59 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
It will look "ok", but it looks better with the T/A center section so that the reflector at the bottom goes all the way across.
you should hold off and try and find a set of 91-92 Trans Am/GTA tail lights since they look sooooooo much nicer.
Old Nov 27, 2006 | 04:26 PM
Pontiackid's Avatar
Car: trans am ws6
thanks guys. anyone have a passenger side light they wanna sell?
Old Dec 6, 2006 | 12:30 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
hey zepher, what modifications did you need to do to get the 91-92 TA lights to work, i just bought myself a set and cant wait to install.
Old Dec 6, 2006 | 03:16 PM
Zepher's Avatar
Only mod was changing out the turn signal sockets. The stock socket is too long (deep) and I just grabbed a pair of sockets from a spare tail light harness I had lying around.
The small running lights just have the bulbs removed and wiring tucked away.
Old Sep 19, 2018 | 07:24 AM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
Re: trans am tail lights?
The 91-92 lights look cool but they look alittle short, Is there a gap at the top of the lights?
Old Sep 19, 2018 | 05:15 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
I believe that's where the reflector strip goes on those, but yea it does look like a gap and the tail lights appear shorter overall.
Frozer!!!
Jan 19, 2024 04:55 PM
TheJoeY88
Dec 31, 2016 07:30 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
