Spohn SCF Install?
Old Dec 12, 2006 | 01:13 AM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
Spohn SCF Install?
Im looking into getting some SFC's, ive been looking at the 1982-1992 F-Body Sub-Frame Connectors I came across soome threads saying there a PITA to install, i was wondering if anyone had any tips, advice, or recomendations. thanks
Old Dec 12, 2006 | 01:27 AM
Firebat's Avatar
Weld them in yourself or have a friend weld them in. Follow the instructions(Spohn's gives instructions), have wheel ramps, have a big bucket of water.
Old Dec 12, 2006 | 01:29 AM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
so does that mean its an easy job to do it yourself?
Old Dec 12, 2006 | 02:06 AM
Firebat's Avatar
I don't know, its time consuming. I had a friend do the welding, I held the sfc's in place, I grinded down the welds to make them look nice. It was easier with 2 people working, I think. And 2 people trying to figure out what to do.
Welding underneath a car with not a lot of room is probably the part that sucks.
Old Dec 12, 2006 | 07:21 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
do you know how to weld?
do you have a grinder or some other powertool to take off the undercoating and to prep the car?
do you have access to a welder?
do you have jackstands/tall ramps?
if the answer is yes to all of that, then its a piece of cake...
Old Dec 12, 2006 | 09:16 AM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
check, check, check, and check. looks like i just got something to add to the christmas list.
Old Dec 12, 2006 | 12:34 PM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
mine went in really easily. bolted up and lined up perfectly. couldnt have asked for an easier install
Old Dec 12, 2006 | 02:27 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
yea, you're all set then..
its not hard, but most of the people on here are missing atleast one thing from that list.
Frozer!!!
Jan 19, 2024 04:55 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SiCkRs
Aug 8, 2015 08:12 AM
