power sander
Old Dec 20, 2006 | 12:46 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
power sander
What kind of sander should I use if at all for remove paint on my car that i want to re-paint with primer color and clear coat.
Should I go air powered or battery?
Should I use a dual sander?
Which brand do you guys prefer?
Any recommendations would be great thanks.
I have a portable sand blaster and air compressor at my disposal.
Should I bother with paint thinner like the air plane laquer remover brand?
Any suggestions?
Old Dec 20, 2006 | 08:34 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
to remove paint fast i use a mikata electric buffer with a 7" velcro backing sanding pad with norton 80 - 40 grit paper it will take you down to bare metal real fast. then i go over the metal with a d/a with 80 grit to be ready to accept epoxy primer. chemical strippings works but its is messy as all heck. and a regular da is fine just takes alot of time.
jeff
Old Dec 20, 2006 | 10:06 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
8 inch DA (mud buster, mud slinger, cookie duster) works very well too....you can get a MAC for like $150
Old Dec 20, 2006 | 10:15 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Yeah, alot of companies make one.
Mikita, Porter Cable, Milwaukee, Craftsman, etc
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
