hidden wires trick in your engine bay
Old Dec 31, 2006 | 12:32 AM
ajk511's Avatar
Car: 1991 z28
has anyone done the hidden wire mod in your engine bay? ogt pics?
Old Dec 31, 2006 | 03:11 AM
84CamaroSS's Avatar
Car: 1984 Camaro
Engine: 350 bored .30 over
Transmission: TCI 700-R4
Axle/Gears: Stock 3.23 i think
I dont get what your asking?
Old Dec 31, 2006 | 09:12 AM
EvilCartman's Avatar
Car: '82 Z28
Hiding all the wires and hoses you can to clean up the engine bay. I've seen one here which looked really good but it's been years since I've seen the pic.
Old Dec 31, 2006 | 10:20 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Would like to see some good pics of cleaned up engine bays.....Am fixxing to do a little cleaning myself this week...Thanks, Tom
Old Dec 31, 2006 | 11:00 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Old Dec 31, 2006 | 12:58 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
the only way that could get any cleaner is if you put in the ac delete box... sweet ride
Old Dec 31, 2006 | 01:16 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
86Z, that is sweet......I need to find me a AC delete box for mine...
Old Dec 31, 2006 | 01:17 PM
ajk511's Avatar
Car: 1991 z28
that looks sweet. where did u run everything? i saw this done on an ls1 and i've wnted to do it ever since, i just dont wanna mess anything up, im prone to making little mistakes lol
Old Dec 31, 2006 | 05:21 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
here's what I did to mine for less than fifty bucks.Battery Relocate, Overflow bottle and abit of polyloom.easy money baby!
Attached Thumbnails hidden wires trick in your engine bay-s4024796.jpg   hidden wires trick in your engine bay-s4024798.jpg   hidden wires trick in your engine bay-s4024810.jpg
Old Dec 31, 2006 | 06:57 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
This is off deadbird.org. The guy has the best true dual exhaust I've ever seen also.
Old Dec 31, 2006 | 07:36 PM
MetalliCamaro68's Avatar
Where did you get the blue hoses? Aslo, where did you put all the relays that were on the driver's side of the firewall?
Old Dec 31, 2006 | 09:50 PM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
It's not my car. the owner runs deadbird.org and has a bunch of pictures, etc of his car there.
Old Jan 1, 2007 | 10:30 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I went to his site and couldn't find any exhaust pics, where did you see them????????
Old Jan 1, 2007 | 11:48 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
If you get a chance look at a mid 80s Vette. The factory did a really good job of hiding the engine harness on those cars, much better than the Camaro. The blue hoses are Goodyear Hi-milers. Silicone rubber deals. Kind of tricky to install without tearing up the outer jacket as they seem to be real soft. Probaby not worth the price except for the look.
Old Jan 1, 2007 | 10:31 PM
Kandied91z's Avatar
like this?
Attached Thumbnails hidden wires trick in your engine bay-eng-comp-without-flash.jpg
Old Jan 1, 2007 | 10:33 PM
Kandied91z's Avatar
or this?
Old Jan 1, 2007 | 10:54 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Holy roller that's old
A post that may be of interest to this one and shows (still old) newer shots of my engine among alot of other extremely nice/clean engine bays is here...
https://www.thirdgen.org/forums/auto...le-wiring.html
Old Jan 2, 2007 | 05:40 PM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
My Cars > 87 Formula > Dual Exhaust
Old Jan 2, 2007 | 09:18 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
im in the process of painting the car and engine bay, and have removed/relocated many wires, dont have many pics yet, but i sure will in about 3 months when the whole project is completed...its guna look real good, ill post pics then
Old Jan 3, 2007 | 10:36 AM
AC's Avatar
AC
Car: Used to drive a camaro
The blue hoses are Goodyear Hi-Miler hoses...available off summitracing for sure...not sure where else. That's Willie's car (sweet *ss true dual setup)
Old Jan 3, 2007 | 07:36 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
May not be the easiest or the best but if I went to hide all my wires I would run my cowl wiring through the cowl in the wiper bay area and put the wires in heater hose to keep them out of the weather.
On the intake, if you turn the fuel injectors around so the connectors are on the underside of the TPI you can run the injector wires under the TPI top part of the intake.
You can tuck the frame rail wires on the side of the frame instead of the top and dump the EPA stuff. This should help. As for the relay's I have never looked around for a new location yet.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
