T-TOP AJUSTERS
Old Jan 3, 2007 | 01:42 PM
gon8go's Avatar
Car: 89 trans am ws6
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
T-TOP AJUSTERS
How do you properly use the t-top ajusters.
Old Jan 3, 2007 | 06:26 PM
Steve86TA's Avatar
Car: To many to list
You have to loosen the 2 screws holding each adjuster,then move it up or down.
Old Jan 3, 2007 | 06:40 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
huh? where are these abjsuters , i think mine need adjusting also as the rubber is now clasing with the window
Old Jan 3, 2007 | 06:46 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Old Jan 3, 2007 | 06:53 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Remove the t-top. Where each t-top pin goes when you latch them in place,that is where the adjuster is located. You have to remove tha plastic trim pieces over these two areas to see the screws that hold the adjuster in place, and which you have to loosen to adjust the latching of the t-top. There are four of these adjusters, two per t-top.
Old Jan 9, 2007 | 01:36 AM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Transmission: TH700R4
Hi,
There's a french article dedicated of the ttop adjustement.
There are several photos to help you.
If you want, I can translate the article.
TTOP adjustement
Old Jan 9, 2007 | 01:43 AM
Gramps's Avatar
Car: 87 Camaro IROC
lol its a good thing that thers pics cuz i dont remember a lick of french from 12 years of education.
Old Jan 9, 2007 | 04:51 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Qui, please translate.
Old Jan 10, 2007 | 01:27 PM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Ok this is the job
1 - This t-top has been unlocked and simply put away,
we can see his rear attach point (passenger side).
2 - A rubber moulding is hold in place by two screws
(see white arrows).
3 - Here's a "zoom in" view of the t-top's attach point
(upper section of the moulding). This part of the moulding hide
the hole where fits the t-top's lock system.
4 - The moulding is now removed ( it's on the top).
5 - We can see here the attach point hold in place by
two screws.
6 - This attach point is ajustable. By loosing the screws,
you ill be able to ajust-it. When it's done correctly, tight the
screws (not too much) and do the same on the other side.
I would thank JM350 who has done the translation, cause my english is very too bad
Old Jan 10, 2007 | 02:20 PM
jm350's Avatar
Car: Camaro 1990
Engine: 352pc. 380hp.
Transmission: 700-R4
That was my pleasure my friend !!
Ç'a m'a fait plaisir mon ami !!
Old Jan 10, 2007 | 02:41 PM
pearl_iroc's Avatar
Engine: LSX
Transmission: MN12
thanks for the translation and the pics buddy it was a huge help
Old Jan 12, 2007 | 12:53 AM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Yes I think and I hope it will help lots of f-body owners
Old Jan 12, 2007 | 01:11 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
merci beaucoup
Old Jan 12, 2007 | 07:20 AM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Originally Posted by ringo234
merci beaucoup
De rien
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
