side mirror disassembly
so i recently had to break the glass on both of my mirrors so that i could completely disassemble them for paint. does anyone know a better way to do with is with the glass in tact as that's the only way i could get to the screw mounts unfortunately.
Dude, are you kidding? You broke the glass to disassemble the mirror? Uh....the traditional way to do it is pull the mirror off the car, mask up the glass, and paint the sucker! I don't think these mirrors were meant to be disassembled!
I don't even see any screws in my mirror assembly...maybe I'm not looking hard enough? But still, why the need to disassemble the mirror? You can get decent enough paint coverage with the mirror intact.
I purchased a used red outside side view for my black IROC. To remove the "mirror glass" all you have to do is "by hand" maneuver the glass (it won't work with the remote) to get to 2 phillips screws holding it on from behind the glass. Once the screws are removed the glass comes right off.
Then I was able to paint it.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I've taken the glass out a few sets....it's tricky to do...but I just manuver the glass it self...applying just a little pressure...and it popped out.
not saying your wrong BlownUp Blue...but if you want to do it the right way....remove everything you can....
nope... i'm serious! The correct way to paint a car is to take everything apart. the quick way is to tape up. if you have to tape up anything on your car you are not painting the car the best way possible and i won't do it any other way, but that's just my problem.
that's the problem... "DECENT" isn't an option with this car which is why i broke the mirrors as a last resort to make sure the paint was the best possible coverage i could do.
when i removed the glass i could get to 3 more screws that removed the actual power motor assembly and plastic mounting plate for the glass and then i could reach the 3rd and final screw of the 3 that hold the actual mount for the motor and glass assembly.
it looks like you would need a special tool to get to that 3rd screw for the main mount.
Axle/Gears: 3.45, 3.27, 3.27
On a 1991, you should have been able to remove the glass mirror without breaking the glass. On early ones breaking the glass was necessary to get to a hidden screw holding the mirror backing plate to the motor. On the later style you manuever the mirror to the far extreme until you can get in behind. There is a cross-shaped piece that is on the motor that snaps into the molded plastic on the mirror backing plate. Once you've got the mirror free there are three screws as I recall to remove the inner frame that holds either the motor or the manual mirror adjuster to the mirror housing.
Lon
Lon
Lon
Lon
this may be the only real way to do it without breaking the glass but i would have to do it on a spare mirror to make sure the plastic wouldn't break on my good one.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I removed the glass and motor assembly from my 89 IROC. There are 3 screws holding it in place by moving the mirror to the extreme positions you should be able to see them and reach them with a screwdriver. 1 of them is hard to find but since you've already broken yours you should be able to see where they are easily. I bought a replacement mirror from a local pick a part junk and repainted it to match my car, but I just masked it off and sprayed inside let it dry move the mirror around and sprayed again.
Car: 1986 Firebird
Engine: V6
Transmission: Automatic
Is there any way that you can post a pic of what it looks like inside of the mirror for those of us that don't know? I thought there were only 2 screws. I'd like to see where this third one is.
i could do that after superbowl weekend. too much going on right now but that's a good idea.
Car: 89 IROC Z28
Engine: 357 TPI
I took a second look at the mirror I replaced and noticed that 1 of the screws was broken off. I was able to gentle pry the glass away from the motor assembly though. I used a very thin screwdriver. Once you lift a small corner of the glass gently work the screwdriver around and it will pop loose.
Here are some pictures the quality of the mirror isn't so good because of the glare.
Lon
Car: 89 IROC Z28
Engine: 357 TPI
Thanks Lon
I do have a practice mirror and using a screwdriver as you described to pry off the glass and plastic backing worked perfectly.
Good to know for the future.
have no idea what adhesive is on the mirror glass you guys are able to remove but mine would not loosen up at all. i was also worried about putting the slightest divit in the plastic surrounding the mirror trying to pry the glass. do you have a picture to point out this piece you say you can snap off safely to remove the plastic assembly? i don't even see it with mine apart?
Car: 89 IROC Z28
Engine: 357 TPI
The adhesive is some kind of rubber silicone adhesive you get in the long tube that needs a gun to dispense. Anyway you don't need to remove the glass from the plastic backing plate. The cross piece that Lon was talking about is the pivot point where the backing plate and the motor meet. It's a round pin held in place by a couple of clips that are part of the motor assembly. They can be pried loose and the glass and its backing plate lift out of the housing.
I have to go to work now but I'll take a picture when I get back.
When I repainted mine, I simply worked my fingers behind the whole glass/trim and gently popped it out
Then removed the 3 screws to get the power motor out
Reassembly took some finesse since it didnt want to pop back in. I took it to a glass shop to see their special way to snap them back in.
It consisted of: positioning the glass, making a fist, and whacking the glass
So can you actually convert a manual window to a power mirror assembly? My car came stock with manual windows, and I recently painted the car. I added all the power options, but held off on the power mirrors because I didn't want to try to match the paint on my car. I actually do have two power mirrors, but they're white and my car's blue.
Yep. I converted my RS 'vert to power mirrors. That's how I discovered about the early and late mirror motors. It helps to pull the wiring from a doner car along with the switches.
Lon
Lon
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
