Fender Removal (Passenger)
Old Mar 2, 2007 | 08:08 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
I did a search, and i found some stuff, but it wasnt too in depth so im starting a new thread. Ive done this a few times on a camaro, but i never needed to do it safely because the cars were being stripped for parts. This time its a different reason, so i CANT break anything.
Anyways, i got all the bolts off my firebird, and the passenger fender is waiting to be pulled. i just dont know what to do with that antenna. There was some mention about a ring? Does someone have a picture of where it is and what it looks like? And ofcourse how it comes off. Also, once the antenna is free, how do i remove it from the fender, to be able to remove the fender completely? If my question isnt clear, just ask. Any help appreciated.
Old Mar 2, 2007 | 08:26 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you have to pull the fender up and off and then on the inside/backside of the fender theres a bracket that holds cable to the car
the ring unthreads at the bottom of the antenna mast and holds it in place on the surface skin of the fender, the round base part, it unscrews counterclockwise should be slots in it
Old Mar 2, 2007 | 08:58 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Really? Thats wierd. Well, the entire fender is loose, but i cant get it "off". Its caught right where the antenna is. Whats that all about? I know theres sort of a bracket that houses the antenna, is that whats holdng the fender?
The frame kinda slopes "up" towards the outside of the car, and the fender doesnt wanna go over nicely past the bump. Seems like something is pulling the fender down.
Old Mar 3, 2007 | 12:05 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok well i looked on the backside of one of a pass side fender i have laying up in the attic
and the cable brace doesnt bolt to the fender,
it bolts to the car tub
heres an antenna assembly off a third gen f body i have laying around here
notice that the round slotted retainer and the antenna mast both unscrew from the cable stud,
unscrew them from the stud and lift the fender up and off that threaded stud
Old Mar 3, 2007 | 01:31 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
look in the door jam area if i remember right i did a trans am front end conversion on a firebird about a year ago
Old Mar 3, 2007 | 05:25 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Randy thank you, exactly what i was looking for. Pix are worth a thousand words, HUGE HUGE HUGE help! Cheers.
Old Mar 6, 2007 | 04:07 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
no prob,. i like to help if i can
Old Feb 1, 2010 | 03:50 PM
therealjcamry's Avatar
Re: Fender Removal (Passenger)
Anyway to get those pictures back, cause now I need to get my antenna off
Old Feb 1, 2010 | 04:08 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
look at your antenna, take the mast off with a wrech or something you will see the stud that the antenna goes on, below that will be a round part with 4 notches in it, use a flat head screwdriver and a light hammer and tap the ring counter clock wise, once its lose take it the rest of the way off by hand
Old Feb 1, 2010 | 04:11 PM
89RS_82Z's Avatar
here is the nut thing im talking about
Old Feb 1, 2010 | 06:27 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
i fixed the pics,
i must have moved location of them in my account, in which therefore changes the URL of the pics,
and then they wont show- with the old location/URL
all better now..
you just unscrew the mast off the base part of the assembly
and then unscrew the round shaped threaded nut thing right below the mast
this threaded nut is hex shaped for a wrench to fit it
the round base assembly nut thing is not and is round with a couple notches etc in it
i usually use a vise grip and a cloth to unthread these.
good luck
Old Feb 1, 2010 | 10:31 PM
Nice thank you guys!
Old Jul 10, 2010 | 04:48 PM
Chrome on Rust's Avatar
Car: 89 RS
Engine: 305 TBI
I would like to send out my thanks as well. I love not having to start a new thread and wait for answers!
BlueIroc-Z
Jun 9, 2019 03:22 AM
fbirdroller
Sep 2, 2015 10:27 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
