!! camaro hood !?
Old Mar 19, 2007 | 07:15 PM
Br0kenxFaith's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
!! camaro hood !?
I have a 91 camaro rs and i am about to buy a 83-84 camaro hood i believe off of a z28 its a factory fiberglass hood with the two indented louvers in the center, longer than the iroc ones, i heard it may not fit my car because of the nosecone on my year...?
Old Mar 19, 2007 | 07:23 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
... I took the hood off my old '83 Z28 and put it on my old '91 RS and had zero problems with it, don't see why you would either.
BEFORE:
AFTER:
Old Mar 19, 2007 | 07:29 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
could you send those pics to my email it wasnt coming up on the screen.. countingstars027@yahoo.com i just want to see it ha cause i want to put this hood on my car i think it would look so nice. thanks.
Old Mar 19, 2007 | 08:27 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Try to find one off an 82 car, the 83s were recalled for separating from the bracing because GM switched suppliers for the adhesive. I have one from an 82 Z28 that I need to get painted. Don't forget to change your hood struts. The lighter hoods need different struts that are softer because the hoods weigh considerably less than the steel hoods.
Old Mar 20, 2007 | 02:13 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Re: !! camaro hood !?
would it fit though if i change struts or would i need other mods for it to line up correctly..?
Old Mar 20, 2007 | 02:15 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
and the hood that im getting is the rare factory fiberglass crossfire one so u have a better idea of what it is..
Old Mar 20, 2007 | 03:20 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
It'll fit, you'll be good.
Old Mar 21, 2007 | 01:48 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
How can you tell the difference between a Z28 1982 and 1983 hood?
Old Mar 21, 2007 | 01:58 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I have a factory fiberglass hood on my 92 RS. They will work, you just have to loose or replace the hood struts (lifters).
Old Mar 26, 2007 | 03:26 AM
90IROCJustin's Avatar
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
it should fit, the body shop down the road swaps parts all the time, he`s got 2 or 3 frankenstein camaros
Old Mar 26, 2007 | 10:20 AM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I swaped an 82 Z28 fiberglass hood onto my 89 RS. Fits great. See my sig. Adam :-)
Old Mar 27, 2007 | 05:00 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You should not have any fit issues. Post pics when done.
Good luck
Old Mar 27, 2007 | 05:16 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Fitment, just get the different struts and it will bolt right on.
As far as the bracing separating from the shell, just get some clear silicone and go around all the supports ive done it on a couple of hoods, makes considerably stronger.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
sailtexas186548
Feb 29, 2016 08:40 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
