Heated mirrors
Old Apr 6, 2007 | 06:31 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Heated mirrors
I've read some speculation here about 84 to 96 Vette power mirrors being the same at 3rd gen ones, and I'm here to tell you other than the wiring connectors, they are exactly the same. I got my set off of Ebay for $49 plus shipping.
Pics are of my stock lens back, and the heated vette lens back. The lens just pops right into our housings with NO modifactions at all. The only mod I did was to cut off the connector for the heated lens, and make two cuts with a razor in the wiring harness for my original power mirrors so I could push the heated lens wires through the grommet and not have to drill extra holes and figure out a new grommet for the additional wiring. After I fished the wires through I taped it back up with a good quality electrical tape. I ran the wires through the stock rubber hose from the door to the door jamb.
Be carefull when popping the new lens back in. They have a small swivel and they pop into a plastic part. Use a little lube on this part and don't do this on a cold day when the plastic is cold. I cracked my stock lens after taking it out to take the pics. Did the heated changover a few days later.
For power I used the stock rear window defroster wire to power a relay to turn the mirrors on when I hit the rear defrost. That way no new holes or switches on my dash, and I have the timer feature on the rear defroster working the mirrors and shutting them off in case I forget about them. The vettes use a 5 amp fuse to power the heated lens, so not much power requirement for them.
This is so easy I'm not sure I'd even call it a mod......more of a minor update really. Was waaaaaay easier than wiring my stereo and amp in. Hardest part was pulling my door panels.
t.com/albums/f107/alloyspecialties/wiring.jpg
Old Apr 6, 2007 | 06:45 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Heated mirrors
Looks pretty cool. Pics of installed product? I don't see much use for heated mirrors, but I guess they would come in handy...
Old Apr 6, 2007 | 07:13 PM
alloy's Avatar
Car: 87 IROC-Z28
Re: Heated mirrors
Well it's 75 deg here now, and I had frost on my windows this morning. Was nice just to hit the switch and defrost the back window and mirrors. Wish I'd have done this before last winter set in. But.....done now for next winter and all the winters and frosty mornings to follow.
Installed pics??? Other than the little heated mirror symbol on the left lens, there isn't any difference in looks at all. No extra switches, wiring is all hidden. Used my original mirror housings, so no difference in the color of the mirrors either.
Old Apr 6, 2007 | 07:31 PM
cdoyle's Avatar
Re: Heated mirrors
Pretty cool mod!
Adding this to my to do list
Old Dec 18, 2008 | 02:19 AM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Re: Heated mirrors
im would assume but do you know if the mirrors would also fit and be adjustable if you did not have power mirrors
Old Dec 18, 2008 | 10:38 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
Re: Heated mirrors
Originally Posted by cdoyle
Pretty cool mod!
yea when i find threads like these i save them and use em later as needed =)
Old Dec 15, 2010 | 03:46 PM
claytonjn's Avatar
Car: '92 Camaro Vert
Engine: 305 TBI V8
Re: Heated mirrors
I know this is an old thread, but thinking of doing this myself. Anyone know if both the pass and drivers side from the vettes are heated, or just the driver's side? thanks!
Old Dec 15, 2010 | 04:02 PM
alloy's Avatar
Car: 87 IROC-Z28
Re: Heated mirrors
Yes both sides are heated.
Old Dec 15, 2010 | 04:16 PM
claytonjn's Avatar
Engine: 305 TBI V8
Re: Heated mirrors
Awesome, thanks for the quick reply. If only they were auto-dimming too...
I just put a bid on a set on eBay - If I can get these and my defroster installed before winter's up that'd be awesome!
On a slightly unrelated note, I got the convertible top with rear glass for my Camaro. I'd like to tint it and install a defroster. I have read that tinting over a defroster gives less-than-perfect results...is there any reason why I couldn't put the tint on first, then the defroster? I've searched online but I guess no one has run into the situation of wanting to add both tint and a defroster to a window that has neither...
Old Dec 16, 2010 | 01:14 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Heated mirrors
WOW, good call alloy! I even work at a Corvette-only dealership and never noticed that. Now I'm just wondering if anyone would notice if one of our white C4s suddenly didn't have the defrost logo on the mirrors...
Old Dec 17, 2010 | 09:07 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Heated mirrors
You can tint over defroster grids and have it look good. If a professional tinter does the work and uses Llumar film or a good film, you shouldn't have any issues.
I have had 15% tint on the back window of my truck for 4 years. The tint is tight against the grids and makes cleaning the rear window easier. I did use another so-called good tint on my wife's rear window and after a couple years, it was lifting at the grids. Llumar is good stuff.
Old Dec 17, 2010 | 09:25 AM
claytonjn's Avatar
Engine: 305 TBI V8
Re: Heated mirrors
Alright thanks for the info. I'll probably ask the people at the shop I go to if they can show me a car they've done with defroster lines so that I can make sure they'll do it good, otherwise I'll just have they tint it first.
Old Dec 17, 2010 | 10:17 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Re: Heated mirrors
Is there anyway to make it autodimming too? Also anyway not to have that defrost symbol on it. Just a blank clear mirror?
Old Dec 17, 2010 | 10:26 AM
claytonjn's Avatar
Engine: 305 TBI V8
Re: Heated mirrors
I emailed Gentex (the company that makes many OEM and aftermarket auto-dimming mirrors) to ask if they had any plans to produce auto-dimming side mirrors for the third-gen camaros/firebirds and C4 corvettes and they said they don't. Maybe if we could find enough interested people they would, but I doubt it. For auto-dimming side mirrors to work you need to have an auto-dimming rear view mirror because that has the light sensors and tells the dies mirrors to dime as well. AFAIK there would be no way to make them auto-dimming unless one of the companies that produces the auto-dimming rear-view mirrors decides to produce them.
As far as removing the symbol, I THINK the lettering on the passenger mirror (and the defrost on drivers) is from where the reflective metal is cut away. I would think they only way to have a blank mirror would be to separate the layers (glass, reflective metal, plastic backing) and put in new reflective metal without the letting. I think it would be more work than it's worth, and I don't think you could ever get it to look perfect. Personally, I like the defrost symbol - makes the car look more "luxary" or "sophisticated"
Oh, btw, I just checked with the tinting shop I was thinking of using and they use LLumar tint
Old Dec 17, 2010 | 10:30 AM
Axle/Gears: G92
Re: Heated mirrors
use LLumar tint
Umm, but If I wire in a auto dimming rear view mirror which plenty here have done then I could run autodimming mirrors.. Hmm I'll figure something out.
It's Luxury btw
Old Dec 17, 2010 | 10:35 AM
claytonjn's Avatar
Engine: 305 TBI V8
Re: Heated mirrors
Yea, I'm installing one of the auto-dimming rear-view mirrors too, that's why I said too bad the C4 ones can't auto-dim. Like I said, you would still have to get Gentex (or similar) to make side mirrors capable of auto-dimming...unless you want to just install mirrors from a newer vette or camaro - not sure how good that would look though...
And yea, typing that much on my phone I'm bound to make some typing mistakes...
Old Dec 17, 2010 | 10:42 AM
Axle/Gears: G92
Re: Heated mirrors
Could you not gut the newer mirrors and make them work in the older housing?
Old Dec 17, 2010 | 10:46 AM
claytonjn's Avatar
Engine: 305 TBI V8
Re: Heated mirrors
Theoretically, but aren't they completely different shape mirrors? You can't use the existing mirrors themselves because the dimming is built into the glass:
"The technology is called electrochromics, which applies electricity in order to tint glass through a low-voltage power supply. The electricity moves through an electrochromic gel placed between two pieces of glass during manufacturing, which have been treated with an electrically conductive coating. "
If you figure something out let me know, because I'd LOVE to have dimming side mirrors. SUVs, even without brights on, blind me from the side mirrors...I'm sure it's the same with everyone else...
Old Dec 17, 2010 | 10:48 AM
Axle/Gears: G92
Re: Heated mirrors
Theoretically, but aren't they completely different shape mirrors? If you figure something out let me know, because I'd LOVE to have dimming side mirrors. SUVs, even without brights on, blind me from the side mirrors...I'm sure it's the same with everyone else...
Same of them are, some are similar I know certain 4th gens exported to Canada had auto headlights but no u.s. One did. Im gonna try and do some research and see what's do able.
Old Dec 17, 2010 | 10:49 AM
claytonjn's Avatar
Engine: 305 TBI V8
Re: Heated mirrors
Yea, definitely let me know what you find.
Old Dec 17, 2010 | 10:51 AM
Axle/Gears: G92
Re: Heated mirrors
Im figuring that someone with a 4th gen has already done this or maybe a export car had these or something.
Old Dec 17, 2010 | 11:17 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Heated mirrors
[quote=alloy;3293895]Well it's 75 deg here now, and I had frost on my windows this morning. Was nice just to hit the switch and defrost the back window and mirrors. Wish I'd have done this before last winter set in. But.....done now for next winter and all the winters and frosty mornings to follow.
Size:  11.0 KB[/quote
What did you use for a switch? I really like this and may have to do this to mine too. If you don't mind.
Old Jan 9, 2011 | 03:37 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: Heated mirrors
From what I read, The mirrors are tied in to the rear window defroster. The switch operates both at the same time.
Cheers!
Old Jan 10, 2011 | 01:57 PM
alloy's Avatar
Car: 87 IROC-Z28
Re: Heated mirrors
Cheers!
Your right, that's exactly what I did.
Old Feb 24, 2011 | 06:22 PM
RoosterC's Avatar
Car: 1988 Maui Blue Camaro
Engine: Pea Shooter
Re: Heated mirrors
Did you have to add another fuse to power the Mirrors? Or did you just splice into the defroster wire? I do tnot have power windows, but imagine it wouldn't be too much trouble to route the wiring and tubing.
Old Feb 24, 2011 | 07:15 PM
alloy's Avatar
Car: 87 IROC-Z28
Re: Heated mirrors
I added another fused circuit. Wasn't sure if the defroster wiring would take the added power requirement.
The hardest part was getting the wires to the mirrors in the doors. The rest was easy.
Old Feb 24, 2011 | 10:07 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Heated mirrors
And don't forget these mirrors also came on other GM cars like the Chevy caprice. a lot of these cars shared the same parts model to model year to year etc.
Old Apr 28, 2013 | 03:16 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Re: Heated mirrors
can someone provide a wiring diagram?
Old Jun 9, 2013 | 12:13 AM
Car: 83 z28
Re: Heated mirrors
I can prob source you one. But in all actuality it's pretty easy to do it without. power, ground. relay, fuse, switch.
Cheers!
Old Aug 22, 2013 | 09:46 PM
atterack833's Avatar
Engine: 6.5 turbo diesel
Transmission: 4l80e
Axle/Gears: 3.21
Re: Heated mirrors
i like the luxury/sophisticated or modern/futuristic feel and function with the stock or barely modded look or at least on the firebird and the symbol would set that off , also im going to be making a auto tint miror of my own , the tint is like $50-$100 for each 12" x 12" sheet and even though i already have a auto tilt miror , im considiring upgrading to a rear veiw screen/compass/auto tint but im going to have sensors in each side mirror , either with a hole in the glass like some of the rear ones , or use the gaps around the glass and the case to let light hit the sensor
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
