Front Emblem
Old Jul 11, 2007 | 05:45 PM
IROC444's Avatar
Car: 1990 IROC-Z
Engine: TPI 350
Axle/Gears: 3.23 posi
Front Emblem
So, I have to replace the Camaro emblem on the nose clip. I tried to pry the old one off but cannot get it. Any ideas on how to get the *%^& thing off? Also, what adhesive is recommended? This emblem didn't come with anything. Thanks people!
Old Jul 11, 2007 | 06:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Front Emblem
Humm, my 85 IROC had a speed nut on the backside of the emblem. I had to remove the black plastic piece, the one that surrounds the hood latch, etc., in order to remove/replace the emblem.
JamesC
Old Jul 11, 2007 | 06:26 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Front Emblem
mine was held on by a few nuts, very easy to get to crawling up under the car or removing the filler panel.
if ya need a new one or if your's has seen better days, modern day muscle has a nice selection. think i'm gonna pick a few things up from them soon.
Old Jul 11, 2007 | 07:49 PM
IROC444's Avatar
Car: 1990 IROC-Z
Engine: TPI 350
Re: Front Emblem
Sure enough, two nuts behing the nose clip under the air filters. Thanks you all, I probably never would've thought of that.
Old Jul 11, 2007 | 08:25 PM
Stephen's Avatar
Car: 87 GTA
Re: Front Emblem
Mine was just double sticky tape, like the side strips. I've never seen a 3rd piece held on with nuts.
Old Jul 11, 2007 | 08:32 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Front Emblem
The original ones were held on with nuts, I have removed many. IMHO it is easier to replace them with double sided tape, most people just rip them from the front bc and the plastic studs break off, hence no studs.
Old Jul 11, 2007 | 08:45 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Re: Front Emblem
Any held on with tape have most likely been previously removed.
Old Jul 12, 2007 | 04:28 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: Front Emblem
Modern Day MUSCLE has several color combinations. Under $30. 3m makes the double sided tape that body shops use fr emblems. Anything else might not stick as well. If you remove the emblem and it has tape on it then it is not the original emblem. OEM's are mounted by two bolts accesable from under the car.
Old Jul 21, 2007 | 03:10 AM
ATCharming's Avatar
Car: 2000 SS
Transmission: a4
Re: Front Emblem
i was missin one too, so i just pried one off with a flathead screwdriver off another car. worked fine lol
Old Jul 21, 2007 | 12:02 PM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
Re: Front Emblem
nice.. stole it off someone elses.. i at least hope it was a junkyard car!
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
69 Six Pack
Oct 5, 2015 07:51 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
