6 inch cowl hood
Old Jul 30, 2007 | 07:39 PM
draglover's Avatar
Car: 1983 camaro Z28
Engine: 383 stroker
Axle/Gears: 4:10 full disk posi
6 inch cowl hood
where is the best place to get a 6 inch cowl hood?
thanks.
Old Jul 31, 2007 | 01:49 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: 6 inch cowl hood
Welcome to the club.
I believe Harwood makes a 4" and 6". Check out the link below. I googled "6" cowl hood" and this is what I got.
http://forums.dragcoverage.com/cgi-b...num=1185755062
Old Jul 31, 2007 | 09:38 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
building a mountain motor under there?
Old Jul 31, 2007 | 10:35 AM
draglover's Avatar
Engine: 383 stroker
sweet thanks! i have a BB chevy 632ci drag engine with a blower on it i want to drop in. it seems like theres going to be a bit of mods to the mounts to make it fit but i havent measured it yet. ether way im going to try to get it in there. i dont want any other car but a 3rd gen haha.
Old Jul 31, 2007 | 11:06 PM
xpndbl3's Avatar
Car: 1984 Z28
if it has a roots blower then use a stock flat hood and just cut a hole in it or else it will look weird.
Old Jul 31, 2007 | 11:19 PM
Hammertime540's Avatar
Car: 91 Camaro RS
Axle/Gears: 3.42's Locker
Cowl hood will be the way to go.
Old Jul 31, 2007 | 11:27 PM
xpndbl3's Avatar
Car: 1984 Z28
not with a roots blower, it will look weird.
Old Jul 31, 2007 | 11:41 PM
draglover's Avatar
Engine: 383 stroker
its low profile but the block is so big it will stick out of the stock hood 5 inches and it would look weird unless i put a scoop on it but i personaly think the cowls look awesome on 3rd gens. what would you guys do scoop or cowl? i could do ether or but i think the cowls look pretty sweet.
Old Jul 31, 2007 | 11:48 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
lol so much for you being able to see anthing on your pass. side lol..6" cowl is crazy
Old Jul 31, 2007 | 11:56 PM
xpndbl3's Avatar
Car: 1984 Z28
the heads will stick ABOVE the hood line by 5" ??? Or do you mean a roots blower is only going to need a 5" cowl hood? I don't see a 5" cowl hood a roots blower and the carbs to feed that motor along with everything else associated. Look at flirtin1 off this board and how his blown engine looks with a stock flat hood and a cutout, the cowls just don't look right.
Old Aug 1, 2007 | 09:38 PM
draglover's Avatar
Engine: 383 stroker
its a low profile blower they are made for the newer mustangs and they happened to have a kit to make it fit on to the motor i have so it wont stick out like 8 feet haha but the block is really big and sits a little high in the car from my measurments and i personaly think i would look kinda silly if theres only half a blower sticking out and i kinda like the cowl hoods it needs about 5 inches of clearence so i figured i'd give it an extra inch for safe measures.
Old Aug 2, 2007 | 06:31 AM
getit's Avatar
Check with Harwood and Glasstech. Nice hoods and smooth to boot. Several people have them around here.
Old Aug 2, 2007 | 02:01 PM
draglover's Avatar
Engine: 383 stroker
i was looking at a used harwood hood the other day with a 6 inch cowl for 150 i might do that not sure yet. it was in pretty good condition though.
Hotrodboba400
Dec 10, 2019 07:07 PM
amargari
Nov 10, 2015 02:09 PM
aharvel50
Sep 21, 2015 07:31 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
