92 nose on a 84 bird?
Re: 92 nose on a 84 bird?
All bird noses and bumpers will bolt up
The ground effects must be used for corresponding years and beware that mounting holes for the ground effects moved for each new style
In short, 91-92 nose will bolt up
If you have ground effects you cant use the old ones with the new nose
If the new nose has ground effects you have to redrill holes for them
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
as a matter of fact i had some kid in an old 82-84 v6 bird with like a 90 nose on it try to race me yesterday
so yes it can be done.
so yes it can be done. Re: 92 nose on a 84 bird?
actually i want like the nose off of a trans am from like 85 or whenever they changed from what mine looks like, of couse mine is a s/e not a ta
Car: 1989 GTA
you will have to get the ground fx for the bumper but it will fit.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
the only one that i know of will be the one on the base Firebirds. It'll bolt right up and basically looks like the one you have now but no grille inserts, just regular non-grill inserts.
The headlights bezels might have to change as yours are really square and the later ones are a bit different....but its a lot less work then the 1991 or 1992 nose swap.
