Primer Suggestions
Old Sep 22, 2007 | 05:08 PM
86FireBird305's Avatar
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
Primer Suggestions
Hey guys
So ive had this ws6 style hood for awhile now and im getting a little tired of it being white... now i plan on having the entire car painted but its gonna beawhile cuz ive come into some hard times and school just started so i have no time to work.
Im thinking of primering it for the time being but i dont know anything about body work...NOTHING! So is there anything special i need to know to do this? Any brand you guys would suggest,do i use the rattle can kind or the spray guns. And lastly what color should i do it do u think red or black...i wanna do red but it would look kinda crappy because i dont think i can even come close to matching the reds darkness.....red primers very light colored am i corect?
thanks
Old Sep 22, 2007 | 07:11 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Primer Suggestions
with the choices you have , flat black for now . i'm not a painter or body man . don't try to rattle can match , it doesn't work .
Old Sep 23, 2007 | 07:49 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
from what i understand primer has no resistance to weather. if it is going to be a while before it is painted i dont know if it would even be worth primering if it is going to be out in the weather at all. i could be wrong and if i am. i would say the color doesnt really matter. black, gray, or red primer, no matter what you do it wont match.
Old Sep 23, 2007 | 03:55 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
got a friend who primed his 4X4, left it gray primer for 2 years off daily driving, mudding, and alabama sun, he could wash the truck with a green scrubby (kind for pots and pans)......he put his paint on it a few months ago without a reprime and it looks great
Old Sep 23, 2007 | 08:16 PM
1badnhra's Avatar
Car: 86 Firebird
Engine: 355 vortec heads
Transmission: 700r4 Huges 2500 stall
Axle/Gears: 4:10
Primer will alow moisture in if its on metal and will eventualy cause it to rust. Since it is a fiberglass hood this will not be an issue. I would say ruff it with at least 600 grit to prep it. Dupla color sales a single stage primer that is ready to poor into the gun and spray, no mixing required. It will be better than anything in a rattle can. By the way, some of the badest cars of the 60's/70's came with flat black hoods
Old Sep 23, 2007 | 09:28 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Go to NAPA. They have quite a few choices for paint and primer and you can even get only a quart. I would recommend a single stage urethane filler primer. However you will need a spray gun to apply a decent primer. In my opinion don’t mess with it until you are ready to paint....even though red is expensive.
Old Sep 23, 2007 | 09:45 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Napa sells the Martin Senour Crossfire paints which are very good. Do not bother with the Duplicolor for spray guns. It's still crap lacquer. Nothing that comes out of a rattle can is worth using.
What state are you located in? I could spray color on that, single stage, cheap, using a gun, if you were close by.
Old Sep 23, 2007 | 10:41 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
They also carry the TP series primer/sealer that can be mixed in nearly any non-metalic color. It is great for filling small imperfections and it retains a good amount of gloss, even after it's fully dried.
Old Sep 23, 2007 | 11:39 PM
Engine: 305 5.0 LG4
thanks for the quick reply guys
ok so first off im located in New Jersey....
i dunno theres just something about a spray gun that makes me un easy but if u guys are saying that rattle cans suck then so be it
i think i wanna do a flat black hood because i really dont think i could match the red either way rattle can or gun....so if im just doin flat black would it matter how i do it? like does rattle can look like ish or is it just really hard to match?
Old Sep 24, 2007 | 12:24 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Use a scuffing pad lightly and evenly. Do a base primer (sandable primer) in whatever color. Then use a primer sealer over that. This will net you the longest lasting and best 'wait to paint' surface IMO
Old Sep 24, 2007 | 12:43 AM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
I primed my neon with spray can primer from Wal-Mart. And painted it with 15yr old ppg paint (freebe) and it turned out okay. It wasn't super glossy or anything. But I would say if your going to be driving the car for a while use a primer/sealer vs just a regular primer. And try to get someone who knows what there doing to help. You could make a big mess if you have no clue what you are doing.
Old Sep 24, 2007 | 12:47 PM
Engine: 305 5.0 LG4
as far as i have seen there are no glossy primers...thats why i just wanted to go with a flat rattle can black...because if im not trying to match the colors then what the difference
Old Sep 24, 2007 | 12:51 PM
Car: 2000 BMW M5
If you're just going to rattle can it, I dont' think there are too many good tips to be given. I would sooner leave it as it is than spray $4 cans of primer all over it, and then have to strip that paint later on. You do not want to spray real auto body urethane over lacquer primer, if you can help it (especially over weathered lacquer primer).
You can probably find a body shop like Maaco that will paint the hood the color of your car for like $150. It will be money well spent to not have a rattle canned, tiger striped hood that looks like crap.
Like I said, I'd spray it if I were closer. I hate to see someone crap up a good hood with spray paint.
Old Sep 24, 2007 | 06:07 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I think what everyone is trying to say there is no cheap fix. But then again you can get a DeVilbiss FinishLine spary gun for $139-159, a quart of single stage urethane primer for $20 and a quart of single stage red with activator and reducer for $80? and lets add another $20 for sand paper and tape. So for under $300 you can put a decent paint job on that hood. And if you screw it up just block sand and shoot it again; you’ll have enough paint. There is no better way to learn than to just go and do it.
Old Sep 25, 2007 | 02:21 PM
Engine: 305 5.0 LG4
agreed....but even that is steep price wise for me....so im gonna way my pros and cons and do some research and still probably wont be able to make a desicion
and the reason i dont wanna paint the hood is because if i do that i might as well do the whole car because the paints 21 years old.
Old Sep 28, 2007 | 08:00 PM
89RS_82Z's Avatar
just to throw out a ????? any of yall ever used single stage automotive paint instead of the clear cote type
Old Sep 30, 2007 | 04:28 PM
VonDoering's Avatar
Car: 92 camaro RS
Engine: 305tbi
Just leave it...its better that the car look good with the red paint and white hood than shitty primer. I see primer cars all the time and they all look like ****...it sprays uneven, washes off little by little with rain and what not...scratches easily. Just leave it until you can afford your paintjob. The fiberglass wont be hurt and neither will your paint.
Old Oct 2, 2007 | 04:37 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
There are several good one's...the best in my opinion, being Imron. Hard to find because of it's toxicity and it's banned in most states. PPG Delstar is another good one. Paint is expensive and you pretty much get what you pay for as far as quality goes.
Old Oct 2, 2007 | 04:44 PM
Car: 2000 BMW M5
Yes. I have used Napa Crossfire, made by Martin Senour. National VOC 5.0 Urethane enamel. It is around $170 total out the door, including a gallon of paint, a gallon of reducer, and appropriate amount of hardener. As far as paint goes, that is pretty cheap for 1.5 gallons sprayable (once it's reduced).
However, single stage is much harder to sand runs out of than clear coat. The pigment in single stage settles through the thickness of the paint. If you cause a big run in single stage, and then you cut and buff it, the shadow of the run may very likely still be visible, due to color shift. I would not recommend a beginner spray single stage. base/clear is much more forgiving. Base is easy to spray, and clear can be sanded and buffed if it does not spray perfectly smooth.
Old Oct 3, 2007 | 04:21 PM
pacecarkid's Avatar
Hey:
I am a few days late in reading your post but if you are not gong to paint the hood right away use a epoxy primer like PPG DP primers as they are water proof and they will seal the hood. I used this on my blazer and drove it all winter in Canada with no problems of rust coming back thru. In fact the
body shop I went to to try to get this painted told me this. Up here in Canada 50- 100 dollars will get you enough to do the hood and you wont have to worry about it. The primer will slightly flatten with time but a quick sand with 600 will have it ready for paint when you are. Hope this helps.
Old Oct 4, 2007 | 12:02 AM
Engine: 305 5.0 LG4
o man i cant make a decision lol
well i truly do appreciate all the imput...
ok so basicly who here thinks it looks good the way it is? this will help me decide
and does anyone think this gives off a ***** vibe at all!
Old Oct 4, 2007 | 09:53 AM
Car: 2000 BMW M5
It doesn't look GOOD white, but it is going to look as bad or worse any other color than a perfect match to the red.
PS: Epoxy primer is expensive. Sherwin williams and NAPA only sell it by the gallon (whereas the sell 2k and paint by the quart and gallon). A gallon of epoxy plus a gallon of reducer and a pint of hardener ran around $130.
Old Oct 4, 2007 | 05:38 PM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
i agree with 86firebird. go with the do it right or not at all idea. perfect match, re-paint the whole car, or nothing at all. the money you save on primer will put you that much closer to having the cash for a paint job
Old Oct 8, 2007 | 02:11 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
YOu also have the option of finding the shoddy backyard painter who needs some quick cash for a bottle of booze. Guys like that have painted several things for me, usually part jobs, just once a whole car. And get it paintmatched in the right colour. I've gotten similar sized stuff painted for 5-800.
Worth a shot. That or ask someone to do it cheaper as a favour, ask them if you could offer some help back. My opnion is that it's cheapest to do it righ the first time, instead of spending on several stages of temporary, and then permanent paint.
Guess that apply's to most things automotive.
Old Oct 8, 2007 | 03:14 PM
Engine: 305 5.0 LG4
ya u get what u pay for....so i think for now until i see a cheap oppurtunity im just gonna leave it alone
although once i do get the money to paint it, im probably gonna have to send it to Maaco which wont be easy for me but i'll have to cross that bridge when i get to it
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
