Which cowl hood?
Old Oct 28, 2007 | 10:06 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Which cowl hood?
I've done some searches but different ppl seem to like diff hoods. I'm undecided on whether to get a Cervini 2.5" cowl hood or Goodmark 2.5" cowl hood. Roughly how much lighter is the Cervini when compared to the Goodmark? I like the look of the Cervini better, however I have the feeling that the fiberglass is weaker and would crack over time. Goodmark is 45 minutes from me so I could save a ton on freight if I picked it up from the factory.
Old Oct 28, 2007 | 10:31 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Which cowl hood?
Goodmark is a good hood. Also you might want to look at the Harwood 2" show hood. It is finished smooth underneath and look flawless.
Old Oct 28, 2007 | 10:50 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
i have a goodmark steel 4 inch and i couldnt be happier
Old Oct 29, 2007 | 06:34 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Pic????
Old Oct 29, 2007 | 10:10 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
A local restoration company can get me a Goodmark 2.5" cowl hood for $438 out the door. Thats about $200 cheaper than a Cervini.
Old Oct 29, 2007 | 10:56 AM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
Originally Posted by 1FastZ
Pic????
well i dont really have a good pic of the hood but this is kinda close
Old Oct 29, 2007 | 11:55 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Does anyone know if a 2.5" cowl will clear a Edel Perf RPM Air Gap, 1" spacer, 700DP with a 14x3" air cleaner?
Old Oct 29, 2007 | 12:32 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it probably will with a drop base..
Old Oct 29, 2007 | 12:34 PM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Transmission: Turbo 400
Axle/Gears: Moser 9 inch/4.56 gears
I bought one from Champion Fiberglass products and am completely happy with it. It took very little prep to paint.
http://www.championfiberglassproducts.com/chevy.html
Old Oct 29, 2007 | 01:42 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
I need a for sure yes or no. I don't want to spend that kind of money on a chance.
Old Oct 29, 2007 | 01:52 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I am running the RPM Air Gap intake with a Holley 750, dropbase with 2" filter under a stock 92 Z28 hood. I have about 1/2 inch clearance. So yeah, you will be fine with the 2.5 in hood.
Old Oct 29, 2007 | 02:06 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
How much of a drop base though? Mine might be a 1/2"-1" drop base at most.
Old Oct 29, 2007 | 09:34 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
I did some rough measuring tonight. I laid a straight edge across the top edge of the fenders and measure how far air cleaner is sitting above the fender and came up with 2.5" roughly. When they say a 2.5" cowl, how do they measure it? I just want make sure I dont order a hood that won't fit.
Old Oct 30, 2007 | 07:32 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Are you already running the intake with a dropbase under the stock hood?
If so and all you want to do is add a 1" spacer, then you dont have to worry going to a 2.5 in cowl. You will be fine and should be able to go to a taller air filter.
Old Oct 30, 2007 | 07:50 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
I currently have no hood at all. My air cleaner sticks about 2.5" above the fenders. I had to run a 1" spacer to clear the accl pump arm on my carburetor.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
