subframe question
Old Nov 25, 2007 | 04:12 PM
kevingrealish's Avatar
Car: 84 Z28
Engine: 350 V8
Transmission: 5 speed
subframe question
I was in a wreck last week and smashed up the front drivers side of my 84 camaro. I found out that the sub-frame is bent - pushed right about 1 1/2 inches. Can I replace the sub-frame itself or is my car dead?
Old Nov 25, 2007 | 05:23 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: subframe question
If you can post pics of the damage,you will probably get alot more help.I have seen people here fix some pretty mangled cars.Chances are that with your pics,some of these people will be able to tell you whether it can be fixed,how much its going to take to fix,and possibly take you step by step through the whole process.Good luck,Tim
Old Nov 25, 2007 | 06:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The subframes are welded in and aren't really replaceable. It might be possible to straighten it, although it might not be worth it.
Old Nov 25, 2007 | 07:10 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
If the front inner structure is simply just knocked over a good bit it shouldn't be a big deal. Most body shops can pull it back straight without issue. If you are willing to do some of the work you can have it pulled for a few hundred and then take it back home and replace the bent panels yourself. If the car is drivable, take it to a few shops for an estimate. Some shops may want you to remove some panels first (if they are only doing the pull). But again, it mostly depends on how the car was hit and what exactly is bent.
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
