Delaminating paint, Best Fix?
Old Nov 25, 2007 | 08:34 PM
ZackD's Avatar
Ok so I bought an 87 Camaro Iroc, its a t-top car with original 350.. says 8 as 8th digit of vin, also has 5.7 liter emissions sticker under the hood.. 144,000 kilometers (not miles)
The car has original paint, and no visible rust
However all the paint is jumping off the factory primer, also original paint is sunfaded.
I read the articles about the water bourne paint, but my car by the vin is a norwood car. So it seems i'm a victim of the crazy primer not the painting process.
I've thought about razor blading the car, or maybe sandblasting the whole thing, but really, it doesn't need it. From what i've read the factory primer on this car has excellent adhesion to metals and plastics, its just that it didn't like the paint bonding to it
What i'm thinking of doing.. is taking the original paint off with 80 or 100 grit paper on my D/A and leaving the factory primer, then doing the whole car in epoxy primer, then high solids primer.. block the car out and go from there
Is this method good for the plastic parts of the car? I've painted a few trucks, never painted much plastic, only some ABS mirrors.
I've heard of people just scuffing the car and going from there, but i'm concerned that the adhesion issues could always be lurking under my new paint and i'm thinking the epoxy primer would "bite" into the factory primer better than just spraying high solids and going from there
How do the skirts come off? Would it be worth while to pull the front and rear bumpers? How do they come off?
Any other suggestions? Has anyone painted a car with the paint delamination issues that sometimes appear on our cars? How long did your method last? Did delamination occur again?
Thanks guys!
Old Nov 25, 2007 | 08:49 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Delaminating paint, Best Fix?
thats what I just spent my weekend doing to my car, I sanded all the paint off, but kept the gm primer where ever I could, but I also had rust to deal with so I went more in depth and took my ground FX off, revaled alot of rust. I too was concerned about the old paint flaking off under the new paint, so I took it all off just in case. if your car is bad enough, you could just use the razor blade, mine wasn't quite that bad though.
Old Nov 25, 2007 | 08:50 PM
ZackD's Avatar
What are you going to use to bond to the factory primer now?
how do the skirts come off?
Old Nov 25, 2007 | 08:59 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
my car wasn't a noorwood car, so my primer wasn't bad like yours, you may be better off getting all your primer off, but then again, Im not really familiar with whats wrong with your primer. I got my old base/clear off, then sanded alot of the gm primer off (not purposely), then used high build primer on the whole car. to remove the gfx on my car you take out the interior plastics in the back, then you'll see 3 nuts, take them off, then go underneath the car and you'll see 3 more bolts to take off, thats just the 1/4 panels. for the rockers, go underneath the car and you'll see a bunch of bolts, take them off, then open the door and you'll see a lot of philips head screws holding the rocker gfx on. for the door, take off the door panel and the weather guard, then along the inside of the door you'll notice 3 or 4 bolts, take them off then on each side of the door you'll see an acorn nut, take it off, and then the door gfx will slide off. atleast thats how it was on my Trans Am, not 100% sure if its the same.
Old Nov 25, 2007 | 09:32 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Thanks guys!
HOLY CRAP!I got a headache reading this.zachd,are you absolutely sure the paint is original?80 or 100 grit seems a bit harsh.My 89 had some nasty looking paint on it when I got it,but I just hit it with 220 on my d/a to remove the previous owners cheap (dollar store primer),and washed the car and then wiped it down with mineral spirits before putting on two coats of two part epoxy primer.I then wetsanded the primer job with 400 grit,and put two coats of color and clear on the car,now wetsanding and buffing the car for hopefully a beautiful finish.
Old Nov 25, 2007 | 09:52 PM
ZackD's Avatar
sorry not sure why you got a headache, i guess my style of writing doesn't agree with you?
Yes.. sure that the paint is original.. and you are probably correct 80 or 100 is likely harsh and would eat right through the primer too
How straight is the car being that you never blocked it at all?
Thnx for the details 87TPI
Old Nov 26, 2007 | 07:38 PM
haha!It had nothing to do with your style of writing,just a long day for me.
Just remove the factory paint and leave as much of the primer as you can since its original.
Forgot to mention,I was in a bit of a hurry when I posted earlier.I block/wetsanded between every coat from primer to clear.Even the color,I used a single stage urethane black,and a clear from same manufacturer.
On your bumpers,you can just give them a light sanding as long as they don't have the hideous paint cracking.If you do though,you have to remove all of the paint,and go from there.I had to do this.I used SEM flex primer on my front nose,rear bumper had no cracking.
Old Nov 26, 2007 | 10:05 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
off topic question, but if I lightly sand my bumpers, leave most of the paint on them, then do I need to use any flex additive?
Old Nov 27, 2007 | 06:40 PM
If the original paint on the bumpers is not cracked anywhere,you should be in good shape to just lightly sand and repaint without any flex additive.
If the paint on the bumpers has stress cracking on them,you have to remove all the finish including the primer,and will need a special primer(like the sem product I mentioned)I didn't need flex additive in my final finish,bumpers don't have enough flex to them to require it with single stage urethane that I used.However,the two part epoxy primer I used had no flexibility characteristics,which is why I had to use the flex. primer.
Old Nov 28, 2007 | 02:15 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Old Nov 29, 2007 | 08:25 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
id just wire wheel the entire car then spray epoxy primer then go over that with high build stuff, then do dent smoothing and blocking
Old Nov 29, 2007 | 11:31 PM
ZackD's Avatar
dude i would need a dozen guys all jacked up on coke or meth or something to wirewheel the whole car.. plus it wouldn't work very well on plastic
of course i could sandblast the whole car.. i could also run around the block 100 times before i took out my garbage... just depends how serious (or stupid) I want to get I suppose
Old Nov 30, 2007 | 12:28 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
ok.....you sand blast it and see how your paint turns out........itll look like a body colored spray in bed liner........i dont care how much you blow it out there will still be sand in the cracks.........use a wire wheel on the big parts, and a DA on the spots closer to the glass and plastic pieces......sand blasting is a last resort....for a rusty POS
its your car do it like you want......but if the primer permits adhesion between the paint......i wouldnt want it on my car
I do this **** for a living......believe me i know
Old Nov 30, 2007 | 07:15 AM
ZackD's Avatar
what do you think of the advantage of using wire wheel verses razor blading the car then?
Old Nov 30, 2007 | 03:19 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
none I can think of, Ive never heard of doing a wire wheel to the whole car before. Id think it'd require alot of feathering afterward, if the paint is peeling bad enough then razor blade it.
Old Nov 30, 2007 | 05:56 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
its just a quick way to get to bare metal, without all the bs of sand blasting.....razor blades work but are slow
Old Jan 15, 2008 | 08:45 PM
You're welcome.
Old Jan 15, 2008 | 08:51 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
You're welcome.
so what if I like to get peoples opinions when it comes to my car
Street Lethal
Apr 30, 2019 12:14 PM
SlowAZ28
Members Camaros
Aug 31, 2015 07:53 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
WIzmo
Aug 30, 2015 02:30 PM
neekolzun
Aug 24, 2015 04:59 PM
