need somthing to get out light sirface rust
Old Dec 27, 2007 | 11:44 AM
likesthemfast's Avatar
Car: 1982 Trans AM
Engine: LU5 CFI V8
Transmission: automatic
Axle/Gears: 3.23 posi
as most of you in the midwest kno we have gotten little snow, but the salt trucks dont seem to care,they have laid down salt every day for a few weeks straight. the salt has ripped the wax clean off my car over the past month or so.Now surface rust is starting to set in. I was woundering if any of you know of any products i can use to get it off soon? thanks
Old Dec 27, 2007 | 12:25 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: need somthing to get out light sirface rust
theres stuff like rust converter that they sell at any auto store and even walmart that turns rust into black primer. or you could sand the rust off.
Old Dec 27, 2007 | 01:34 PM
faith1's Avatar
Car: 87 Trans Am T tops
Engine: 305 TPI motor
rust guite like anything only gets worse with time. even if you cant do anthing with it today I would sugesst at least throwing a quick coat of wax or something on it before the rust has any more time to set in. this will help slow the oxidation process a bit and give you time to fix it proper. when you go to paint back over it though ensure you strip the wax off with a stripper and then some rubbing alcohol with a clean tack rag. this has worked for me on other cars in the past and kept the rust from getting worse till i could get to it
Old Dec 31, 2007 | 07:43 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
rust converter is a good idea but remove as much rust as you can with wire brush, sand paper, what ever it takes before you use the converter. another thing i have been told is that wax holds up better if you just apply it and dont wipe off the haze. you may want to try waxing the bottom of the car and not buffing out the haze.
Old Jan 7, 2008 | 09:48 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
this is exactly why you park your nicer rides and drive the winter beaters when you live in the midwest here
once rust is through the paint then it is all over
too late
it will only get worse from there
should have been not driving it in the snow and salt
start sanding and prep for new paint
ship it to FL GA AR TX MS NV NM CA for the winters
even KY TN SC NC OK and such are way better than up here
lots less snow and salt than up here by FAR
everything rusts eventually in most locations
nothing much you can do esxcept store them away dry over winter
if you drive it then it will rust
good luck!
Old Jan 9, 2008 | 01:29 PM
fenton06's Avatar
Originally Posted by Randy82WS7
this is exactly why you park your nicer rides and drive the winter beaters when you live in the midwest here...should have been not driving it in the snow and salt
Some of us can't afford to have a winter beater , so at least offer some good advice, other than "don't drive your car in the winter.
Assuming (hopefully) you don't have awesome/perfect paint, use a wire wheel if the rust is really thick, but if it is surface rust sand it off. After that give it a coat (or two) of rattle can primer until you can either spray something else or paint the entire car.
Old Jan 9, 2008 | 05:36 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
You need primer and also primer sealer.... You can still get rust with plain jane primer.
Old Jan 9, 2008 | 11:28 PM
fenton06's Avatar
thank you for the clarification, I left that out...
Old Jan 10, 2008 | 12:43 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
something that worked great for me is something called a flap disk. You use it on your angle disk grinders. It's multiple layers of sandpaper stacked up in a disk formation, worked great for me, comes in multiple grits so that you can do course to get hard rust off and then use a finer grit to smooth it out. This will not tear into your metal like a grinding disk or cutting disk, it will just scuff up the surface and take the paint and rust away in seconds. Afterwards I've heard of using epoxy primer any time you get any metal down to bare metal, but i have always used etching primer, not sure if they are one in the same, but it's a suggestion if you got the tools. Otherwise sand it down ASAP, it's never too late to save it, IF done right...you can stop anything, you just have to catch it early enough. Good luck!!
deracer
Apr 11, 2016 12:04 AM
ambainb
Aug 29, 2015 12:43 AM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
Omega
Aug 10, 2015 12:46 PM
