Removing heavy front bumper support
Old Jan 2, 2008 | 01:38 PM
brian schuetta's Avatar
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
Has anyone removed the front bumper support from their Camaro? The thing weighs a ton and is hanging right on the front of the car. I want to remove it but don't want the front end to distort at speed and would like to keep the lights that are attached to it. Maybe cut out just the center of it and the far outside and keep the parts that mounts the lights. Any experience with this out there?
Old Jan 2, 2008 | 01:57 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: Removing heavy front bumper support
Not sure if you are talking about the crush bumper or bumper support. The bumper/light support is not heavy and has to be there. Crush bumper can be removed but next time you crash you will have lots more damage than with crush bumper
this picture is with the crush bumper removed with bumper back on:
and here is the picture with the crush bumper removed but the headlight bar in place(bumper off)
light/bumper support bar by itself
crush bumper (damaged)
Old Jan 2, 2008 | 06:58 PM
Engine: 383
Transmission: th350
I want remove the part on the ground in the last picture. It's bolted to the end of the frame and it's heavy.
Old Jan 2, 2008 | 07:56 PM
Pocket's Avatar
Car: 91 Trans Am
Its held in by 4x 13mm nuts on each framehorn
It is a VERY important safety item and will likely save your life in a head-on collision
If you do remove it, put something back in there
Old Jan 2, 2008 | 08:53 PM
AC's Avatar
AC
Car: Used to drive a camaro
Like previously stated.....VERY IMPORTANT function for that piece. IF you remove it do something like Andris Skulte has done or something even beefier. I say beefier because I think his car is only a track car now. You take that piece out and you've taken pretty much the first defense in a front impact. If that part isn't there you don't have any other steel to help other than your frame and etc.
Old Jan 2, 2008 | 09:25 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
i believe camaros and firebirds did at one point come with aluminum bumper supports, can't give you any info past that, just know they are out there. Saved a lot of weight in the front.
As mentioned above, i would NOT suggest running around without anything up there for the sheer fact in the act of an accident, i'm willing to bet an insurance company will not cover you. It's a law, you don't need the bumper cover but you do need the bumper support. (NY at least)
Old Jan 2, 2008 | 09:39 PM
Pocket's Avatar
Car: 91 Trans Am
Some 82-84 Fbodys came with the aluminum impact bar
The weight difference is noticeable but not something major
Old Jan 2, 2008 | 09:44 PM
84redta's Avatar
just a thought if he wanted to shave some pounds, hand in hand i've heard it is noticable, but i would assume it illegal to remove the bar all together, so every pound shed is good at this point.
Old Jan 2, 2008 | 09:53 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I'm not sure it can be used with the later bumper covers though. I've not tried the swap, but comparing the two, it doesn't look like it will work.
Old Jan 2, 2008 | 10:38 PM
Pocket's Avatar
Car: 91 Trans Am
Ive read direct swap, ive read you have to cut a few inches off each side
Either way its very easy and pointless
Old Jan 2, 2008 | 10:44 PM
Car: numerous
Engine: ls1, others
i seen on the forums before that somebody had to cut 2" off each side to get it to fit. Not sure if it was because one of firebird and other camaro or year difference
Old Jan 3, 2008 | 05:54 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Don't risk your life trying to save weight. It isn't that heavy anyway.
Old Jan 3, 2008 | 06:35 PM
Engine: 383
Transmission: th350
Well it was just an idea. The car is track only and around a mid 12 et.
Old Jan 3, 2008 | 07:09 PM
84redta's Avatar
replace with aluminum or steel pipe so that you have some protection but not all...i didn't know it was just track...but as mentioned above, you hit the wall, you got NOTHING to protect you, if you put a bar across where that huge steel bar is...you at least have some protection and the front can behave as it should in an impact.
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Wylecoyote08
Aug 22, 2015 01:58 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
