rear hatch ?
Old Feb 23, 2008 | 02:46 PM
92WhiteZ28's Avatar
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
rear hatch ?
im doing some work on my project IROC that i got a couple of months ago, and there are some interior peices in the rear hatch that i cant get to from the inside, and i dont have a key to the hatch. can i get it open w/o the key? i know there is supposed to be a release by the window switches but it dosnt work. any ideas?
Old Feb 23, 2008 | 03:15 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: rear hatch ?
Your hatch release switch only works when in park or neutral. It will only work it the park/neutral safety switch is hooked up. You should be able to jump it with a battery too. Otherwise someone is gonna have to tell you how to take off the tail lights and find the lock rod for the hatch and twist it.
Old Feb 23, 2008 | 04:56 PM
92WhiteZ28's Avatar
Re: rear hatch ?
u make me sad
Old Feb 23, 2008 | 04:57 PM
Axle/Gears: 3.27 BW
Re: rear hatch ?
What say you? You have no chance to survive.
I can take pics of the wires. My center console's gone. So is my carpet. And a lot of other things. Like my dignity.
Old Feb 23, 2008 | 07:50 PM
92WhiteZ28's Avatar
Re: rear hatch ?
yea, go take pics of them, hopefully i can get to them. im going to take out the center console and clean it and stuff. and replace the broken parts lol.
Old Feb 23, 2008 | 10:13 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: rear hatch ?
worst case scenerio it's just about very simple. Climb in the back, disconnect the hatch shocks (be careful, because of the force you can screw up the threads where the stud goes into if you let it quickly extend on their own), take off the roof plastic piece right over the rear passengers to reveal the hatch bolts, have someone stand outside the car that can support the weight of the hatch, disconnect the four bolts, lift up about 6-8 inches, get a saws-all and cut the first loop of the latch, lift up to about 12-18 inches higher, have the person outside ready to have the weight of the hatch come at them (won't be alot becuase of the angle) and cut the second loop of the latch, and the door will want to slide down, just lower the upper part of the glass back down, put the four bolts back in the holes and bolt them down. Now you can open your hatch without a problem. When all is said and done, if done carefully you won't have to replace any interior panels, and all you will have to do is spend $5 at a junk yard for a new latch bracket and about 20 minutes re-aligning the hatch and all is said and done, and from there you can figure out what your going to do about the keys.
Sounds absolutely extreme, but i've had to do it four times, and each time i haven't harmed the interior panels or the hatch, and as mentioned all you will need to do is go to the junk yard and take the hatch cover off, remove four bolts for a good latch loop, and then go home and replace yours.
Old Feb 24, 2008 | 11:13 AM
Axle/Gears: 3.27 BW
Re: rear hatch ?
Short the black wire in my hand to +12v. Any source of +12v. It should release your hatch. If not, then something is wrong back in the well area, and you're gonna have to remove your tail lights/jiggle the lock rod, or sawzall.
Old Feb 24, 2008 | 11:46 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: rear hatch ?
It's easier than that, if you don't have a key drill out the lock, open with a screw driver, get a keyed lock and replace.
Old Feb 25, 2008 | 01:50 AM
92WhiteZ28's Avatar
Re: rear hatch ?
i thought u had a center console the day i came down...what happened?
Old Feb 25, 2008 | 09:19 AM
Axle/Gears: 3.27 BW
Re: rear hatch ?
To remove the carpet, one must remove the console.
To acquire new carpet, one must have serious $$.
Old Feb 25, 2008 | 05:38 PM
92WhiteZ28's Avatar
Re: rear hatch ?
lol, ive still got my eye out for capet for ya. not this weekend but next im going to the yard and will definatly get those switches for ya. and ill prolly look for the thing im gunna cuf off of my hatch too lol.
Old Feb 25, 2008 | 06:00 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: rear hatch ?
I open hatches in the junkyard by pulling on the cable that goes from the pulldown to the lock cylinder
Old Feb 25, 2008 | 06:41 PM
Axle/Gears: 3.27 BW
Re: rear hatch ?
Shorting that wire to +12 didn't work? That sucks.
Old Feb 26, 2008 | 07:44 PM
92WhiteZ28's Avatar
Re: rear hatch ?
i havnt tried shorting the wire yet. i dont have the battery hooked up because i am hal;fway through the re-instalation of the wiring harness. i am kinda overwhelmed with all these connectors.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
