WTB Driver's side Quarter patch panel Firebird
Old Mar 3, 2008 | 09:55 AM
maj75's Avatar
Car: 1983 Mecham MSE Trans Am
Axle/Gears: 10 bolt Posi, 3.something
Looking for leads for a lower patch panel for the driver's side. I have as 1" hole on the underside of the quarter panel where the drain hole was supposed to be. I have seen a small patch panel on the Brown's website but it is out of stock.
I don't want to buy the entire quarter panel and cut out such a small piece.
Any assistance appreciated.
Old Mar 3, 2008 | 12:32 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Re: WTB Driver's side Quarter patch panel Firebird
I have the same issue. I called Hawks and he wanted $100 and a lot for shipping. I am just going to cut my own from a car in the junk yard. I will post pictures of the whole process when I get into it.
Old Mar 3, 2008 | 12:54 PM
maj75's Avatar
Good Luck. This is first place a car will rust, especially if it is a northern car. My car is 99.9% rust free and it has rust in this area due to the plugged drain hole.
I ordered a camaro patch panel from Brown's for $29.00. The piece I need is so small, I won't feel bad about cutting this piece up. You can't even see the area with the rust as is is underneath the quarter panel, closest to the ground.
Old Mar 3, 2008 | 01:22 PM
ponykilla's Avatar
honestly i am in autobody and the best thing to do would be to contact keystone www.keystone-auto.com that is all my shop uses and we get things like that all the time and they are really good about carryin parts like that in stock
Old Mar 4, 2008 | 02:17 PM
maj75's Avatar
I went to the site. It is ID/password protected. You have to be in the business to place an order...
Old Mar 4, 2008 | 03:58 PM
Firebat's Avatar
If you can't even see the area without crawling underneath the car, why not just buy a piece of sheet metal from any hardware store and weld it in?
You may want to check out the drain holes behind the front seats for rust also.
Old Mar 4, 2008 | 09:03 PM
maj75's Avatar
Everything else is great!
The rear drain hole got plugged with seam sealer at the factory. The rest of the car is spotless!
Old Mar 4, 2008 | 09:39 PM
DRS50's Avatar
Is this what you are looking for, www.paddockparts.com # 69960L Left side rear lower repair panel. The right side is the same # just replace the L with a R.
Old Mar 4, 2008 | 10:41 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I just looked it up and its only $32.95! For that price it's not even worth my time to go the junk yard.
Who is Brown's?
Old Mar 5, 2008 | 12:51 PM
ponykilla's Avatar
see the great thing about keystone is your local orilleys carries their catalog so you should be able to find it in there they are like twice the size of a bible so i think you should be ok there
1992 Trans Am
May 10, 2023 07:19 PM
TA8487
Aug 16, 2015 12:21 PM
Street Lethal
Aug 14, 2015 08:25 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
blacksunshine'91
Aug 10, 2015 12:04 AM
