HOOD LOUVER MOUNTING STUD FIX?
Old Apr 15, 2008 | 06:09 PM
400HP88IROCCONV's Avatar
Car: 2007 R/T-R package CHARGER!
Does anyone here have a surefire fix for broken & dry-rotted hood louver mounting studs? I've broken them before, & this time there was absolutely no way around it. It seems to me there should be a prescribed repair rather than dropping over 2 bills on new ones.
Old Apr 15, 2008 | 07:48 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: HOOD LOUVER MOUNTING STUD FIX?
I'll tell you what I did. I bought a stick of 1/4-20 all thread and cut that into 2" pieces. Buy some nuts also so you can retain the threads if your cut is bad (install 2 nuts and cut inbetween them so you can remove them and it rethreads itself ). I then removed the plastic studs, or whatever was left of them with what ever I had handy. Buy some good epoxy, set the all thread, let cure, and there you go.
Old Apr 15, 2008 | 09:12 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
That's a great idea. I'll be taking my louvers out for refinishing soon and was wondering what I would do if the stud snapped when I tried to take the nut off.
I did a similar thing on the rear seatbelt grommets around the hole in the side panel of my vert. I replaced them about evey year for a while since the mounting stud broke whenever someone sat crooked in the rear seats or pulled wrong getting the belt out.
I drilled out what was left of the broken stud and replaced it with a bronze machine screw. The interior is medium beechwood, so they match preetty good.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Bert87
Aug 23, 2015 03:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
