windsheildwipers not working right help!
Old May 6, 2008 | 01:34 PM
Rva's Avatar
Rva
Car: 1984 z28 camaro
i used that gunk stuff to clean my engine and after i was done my windsheild wipers dont work except for on high. and they wont go back down..... anyone have any idea how i can fix this?
Old May 6, 2008 | 02:35 PM
BAD INTENTIONS's Avatar
Car: 1991 Chevy Camaro...
Engine: 406 With Many Mods..
Transmission: Turbo 350...Hurst Quarter Stick...
Axle/Gears: 373 Gear..Posi Rear End...
Re: windsheildwipers not working right help!
Slight chance it's the Wiper Motor since they do work on high...But you could try to Disconect the battery for 10 minutes or so and then see if the Wiper Motor will reset it's self. Ya most likely got a Bunch of that Gunk Clogged in there. And it needs to clear itself out..Go to Auto Zone they are Cheap to buy if ya end up needing a new one....
Old May 6, 2008 | 11:32 PM
DaveBerlinetta's Avatar
Car: 1985 Berlinetta
Engine: 5.0 LG4
Axle/Gears: 3.08 Peg Leg
I just had a similar problem with my wipers. I removed the cover to replace the pump. After reassembly I would only get high speed and they wouldn't park when turned off. After a week or so of fixing parts that I broke (loooong story), I just got them fixed tonight.
I have an '85 Berlinetta with the touch control pulse wipers. I didn't realize that I needed to remove the end plug when removing the cover assy. I had left it on, but was able to remove the cover anyway. After mounting the cover, the contacts from the park switch assy weren't being 'seen' by the wiper electronics. Putting the plug in AFTER mounting the cover fixed it.
What type of wiper system do you have (standard, pulse, touch)? Did you take anything apart?
The troubleshooting chart shows either a bad circuit board, motor, or park switch, depending on which system you have.
My guess would be that you got water inside the cover. Hopefully it will dry out in a day or so. If it still doesn't work, I'm afraid you may have fried the electronics. If so, you may only need a new cover assy. Any decent junkyard should have them.
Good Luck!
Old May 7, 2008 | 11:38 AM
Rva's Avatar
Rva
its been like a week and it still doesnt work but i havent tryed to unhook the battery yet
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
