Weatherstriping Question?
Old May 29, 2008 | 03:17 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just bought a pair of door opening weatherstrips for my car. My question is, is a weatherstriping sealer/silicone something that definetly has to be used or will they seal fine without it?
Old May 29, 2008 | 03:32 PM
net_coma's Avatar
Re: Weatherstriping Question?
There is a weatherstrip adhesive made by 3M. I have looked at the weatherstrip on mine trying to determine if it will be destryoed during removal for painting but can not tell if all of it is free of adhesive or not. Along the door edge I do not think it is glued but up near the top where the material is larger and thicker I am not sure.
The doors seal well and no wind noise.
Old Oct 18, 2009 | 06:16 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Old Oct 18, 2009 | 09:36 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I ended up using a weather striping sealant and it worked fine for me.
Old Oct 18, 2009 | 09:53 PM
KITT1983's Avatar
Do you have any pictures or links of the weatherstripping sealant that you used?
Old Oct 19, 2009 | 09:30 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I don't have any pictures of the stuff I used. It was just a weather stripping sealant that I found at advance auto parts.
Old Oct 20, 2009 | 06:39 AM
KITT1983's Avatar
do you know what is was called?
Old Oct 20, 2009 | 12:57 PM
mikeiaz's Avatar
it is not necessary to use any adhesive or sealant - you can if you want to, but not necessary
Old Oct 20, 2009 | 04:00 PM
1Aauto's Avatar
Former Sponsor
X2...Just Glue them in where recommended and your good to go.
Old Oct 20, 2009 | 05:53 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Permatex Black Rubber Sealant
Old Oct 20, 2009 | 06:11 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
I just installed mine about a week ago and I only used adhesive on the ends at the tops of the doors. I used the 3M weatherstrip adhesive. It's yellow but it comes in a black tube.
Old Oct 20, 2009 | 06:16 PM
KITT1983's Avatar
do you guys have any leaks?
Old Oct 20, 2009 | 08:16 PM
FYRCHKN's Avatar
Engine: LT-1
Nope, none that I know of. I drove the car about 100 miles today. It's the first time it's left the driveway since May and I just replaced ALL of the weatherstripping on the car. It's 1000 times tighter than it was before. The doors shut solid with no more rattling.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
