cracks in tranny tunnel
Old Jun 4, 2008 | 09:47 PM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
there are cracks in the paint in 2 places and the metal looks like it's buckling
I'm hoping that I'm imagining things ... would someone comfirm that I'm not imagining things.
Old Jun 8, 2008 | 08:12 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
Re: cracks in tranny tunnel
No, you're not imagining things! Looks to me like the tunnel is buckled in front of the shifter boot and under the boot also. Has the car been in a hard frontend collision? Or did someone pull a Dukes of Hazzard move to it, you know, jumped it? I realize that would be hard to tell.
Old Jun 9, 2008 | 08:03 AM
uemf's Avatar
Car: '86 Firebird
I found that it took a good lick on the front drivers side... the frame rail looks like a piece of cooked bacon at and in front of the radiator support and has probably close to an inch of shims (ok, probably more like half an inch) to make the front end components square up.
Man, I was ticked off when I found that .
I checked the rocker panels and they don't look buckled so I'm trying to figure the best way to go with this ...
I'm thinking, jack up the car in the middle( not all of the weight, just some to see if it gives) and weld a brace across the area.
and thanks for the response...
Old Jun 10, 2008 | 10:35 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
If that was buckled from a wreck, chances are the doors wouldn't even close.
Looks like the tranny mount was/is broken and the tranny smacked the tunnel a few times... or countless times.
Old Jun 11, 2008 | 11:10 PM
uemf's Avatar
Car: '86 Firebird
the tranny mount had given way when my step son was driving this car... but the damage to me looks like the metal has been caved in,not pushed out, especially at the base of the shifter boot.
Since this is the only 3rd gen I've seen this close, I could be wrong.
Tony
Old Jun 11, 2008 | 11:17 PM
3SLO5's Avatar
Car: all over the place
Engine: the best one around
Transmission: lots of them
Axle/Gears: richmonds
deffinitly from the accident i had a 85 manual ta and it looked identical to your pic my car was also hit on the ps front real hard upon further digging mine once had the whole rad support changed as well as the ps strut tower the whole thing was replaced but my doors and everything else lined up fine.
Old Jun 16, 2008 | 11:50 PM
hellraiser319's Avatar
definately a wreck. mine has something similar, the pass rear floor has a nice buckle at the tunnel, and the driver side under the front seat has another... looks like the car rear ended someone with what repairs i seen on mine... as long as the car is straight and solid no big worries, mine has survived 14 years repaired i found out...
Old Jun 17, 2008 | 05:55 AM
uemf's Avatar
Car: '86 Firebird
thats good to hear, at least that it's not the end of the car... she tracks true so I'm assuming that whatever work was done at a good bodyshop.
I do appreciate the responses guys
Tony
sheachopper
Jul 31, 2019 11:27 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
bjpotter
Oct 4, 2015 07:48 PM
