Headlights and T Tops
Old Jun 7, 2008 | 11:06 PM
LoveMyRS's Avatar
Car: 92 Maro RS
92 Camaro
Driver side headlamp wont turn on in low beam.
I turn on my high beams, and all 4 headlamps come on as they should.
Most likely wiring, but where to look first? Any advice would be great.
Also, where would be the best place to get replacement T Tops?
Old Jun 8, 2008 | 12:04 AM
asting's Avatar
Re: Headlights and T Tops
the junkyards probably your best bet. I picked up a decent glass pair for $40.
Pretty much any will fit, however some slight modifications are needed. You sometimes need to slide the bracket up or down for the locking part of the t-top. There's a bracket in the front, and back.
Old Jun 8, 2008 | 12:11 AM
LoveMyRS's Avatar
Car: 92 Maro RS
So for the tops, look for any set from a 3rd gen? Would it be better to look for a set from a 90-92 so I wont have to alter them in anyway? Any online places that are reputable but worth the money?
Old Jun 8, 2008 | 12:21 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Originally Posted by LoveMyRS
92 Camaro
Driver side headlamp wont turn on in low beam. I turn on my high beams, and all 4 headlamps come on as they should.
Low beam filament on the driver side is burned out. The outside lights have 2 filaments, thats why they have 3 terminals on the back - low, high, ground. I'd buy a pair and replace both and keep the good one as a spare.
Junkyards can be hit and miss. The glass will fit (unless you have the C&C style tops). You may have problems finding the same latching mechanism as they changed through the years. Some of the pins are different diameters and some early ones used a hook and eye type mechanism. Easy enough to remove the mechanism from your current tops and transfer them to the new ones.
Old Jun 8, 2008 | 12:24 AM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
the onley place online that i know has new t-tops is http://www.camarottops.com/ but they what like 200$ per side for a used set and 800$ for a new set so i havent bought from them
Old Jun 8, 2008 | 02:11 AM
LoveMyRS's Avatar
Car: 92 Maro RS
pair of?
Old Jun 8, 2008 | 02:17 AM
EvilCartman's Avatar
Car: '82 Z28
ummm replacement headlights.
Old Jun 8, 2008 | 09:29 AM
asting's Avatar
I'm pretty sure the 90-92 where not actual glass. I grabbed a pair from an 89 firebird and they worked out fine. ha one way I checked was found a 90-92 camaro and tested them in it :P. If it doesn't fit right away that doesn't mean it won't work at all. Sometimes the locking brackets on the car itself need to be raised or lowered.
Old Jun 8, 2008 | 11:16 AM
Al Hasse's Avatar
pair of?
Yup, replacement sealed beam headlights
Old Jun 8, 2008 | 12:39 PM
NobleHdwe's Avatar
They had both glass and lexan t-tops.
Old Jun 10, 2008 | 12:18 PM
LoveMyRS's Avatar
Car: 92 Maro RS
lexan.
btw thanks for everyones help. i fixed the headlight.
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
Catcher55
Aug 15, 2015 07:08 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
