cleaning out under hood
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Well i got my engine out and would like to clean out the engine bay. Have tried and angle grinder with 120 grit on it but its just to much power for that. How do you guys reccomend doing it.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: cleaning out under hood
how much are you trying to take off? if its just a scuff and paint
, if you want to totally strip it and start from scratch, chemical paint stripper works great and gets into all the nooks and crannies.
other option, electric random orbit sander
, if you want to totally strip it and start from scratch, chemical paint stripper works great and gets into all the nooks and crannies.other option, electric random orbit sander
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
no i dont want to have to stip it but i want it to look nice smooth and glossy.
and the engine enamal paint looks like a rough paint what do you guys reccomend.
What are you trying to do? On my 82 Corvette and 88 S10 Blazer I used a combination of engine degreaser, scrub brush, and Purple Power and then hit it with a pressure washer......it cleaned it really well and good enough for paint.
I used eastwoods "engine paint" for my vette and used PPG omni base coat/clear coat on my blazer...the black in the engine bay on that is just "low gloss" hi temp engine paint from autozone
My vette
My blazer
My vette
My blazer
Car: 1990 Cadillac Fleetwood Brougham
Engine: Chevy 350 TBI with some goodies
Transmission: TH-7OO-R4, waiting for rebuild
Axle/Gears: Stock. Saving for 3.73 posi unit.
I used "Purple Power" when my engines was out. I let it sit overnight then hit it with a power washer. Like the previous post says. That stuff is amazing. Where gloves when your spraying it on.
Car: 2015 Chevy SS
Engine: LS3
Transmission: 6L80E
Car: 87 Fomula, bought new, October 86
Engine: 305 Quadrajet,
Axle/Gears: 9bolt now in, starting on body work
I'd suggest that every part of the engine compartment gets detergent washed several times before any sanding or grinding is done to keep grime and goop from getting inbedded in the metal or existing paint. Nothing will ruin your new primer and paint than a load of contaminants. Looks like a lot of hand sanding to get around all the curved places but it will be worth it later.
Good luck
Good luck
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
