Help opening hood
Old Jul 30, 2008 | 03:54 PM
1970 Buick's Avatar
Car: 1989 GTA
Help opening hood
HI, anyone have a good way to open a hood that won't respond to the interior pull handle? Thanks in advance!
Old Jul 30, 2008 | 04:04 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: Help opening hood
When mine was doing that, I had to hit the front of the hood right above the latch with my palms and play around with the release cable to get it to open. It normally took me 4-5 tries to get it to open so it is a little tricky. I would try that first, mainly because I can't think of any other way to do it.
Old Jul 30, 2008 | 04:08 PM
CHAMARO's Avatar
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
look up underneath the dash and see if the cable is moving when you pull. if not pull the cable by hand or with pliers. If it is see if you can get a visual on the latch and cable from under the vehicle or from the fender well and see if the latch is what is failed or if the cable failed. If the technical approach doesnt suit you, try a pry bar. oh, also if you can hear the latch operating and it doesnt POP, hit the hood with your hand while having someone hold the handle back. this happens as well sometimes when the striker sticks.
Old Jul 30, 2008 | 04:21 PM
'86 Camaro BoSs's Avatar
Car: 1992 Camaro RS - 1971 Chevelle
Engine: 3.1L - 5.7L
Transmission: T-5 - TH350
ooorrr you could just do it the easy and quick way, get under the car (idk how big you are, i'm about 5'7 and 160 and i can slide under no problem. once you get under, just reach up and pull the latch that's holding it down, then once you have it open, make sure the cable's hooked onto the little clip inside.
Old Jul 30, 2008 | 05:49 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
that happened to me once, lost the cable because the clip broke. get up under there and open it up.
Old Jul 31, 2008 | 09:06 AM
camarobird92's Avatar
Car: 95 Z28, 92 Camarobird
Engine: 410 rearwheel hp LT1, TBI 305
Transmission: 4L60E, 700R4
Axle/Gears: 4.11's, Whatever BS GM put in it
I always thought the hood not opening was a normal camaro thing. I've had four 3rd gens now, and every one of them needed a little love tap to open the hood. You just have to hit them a little right above the latch.
Old Jul 31, 2008 | 03:56 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
lube the locking mech with some grease
Old Aug 1, 2008 | 09:38 PM
1970 Buick's Avatar
Car: 1989 GTA
Thanks a ton guys! I tried hitting it a little with my hands and it took about 5 times and then it finally popped. I lubed up all the parts and it is popping every time now. Thanks again for all your help!!
Old Aug 2, 2008 | 05:48 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Yeah, GM designed these cars so you'd have to smack the hood to get it to open...
My hood started doing that and I took 30 seconds and just adjusted the latch mechanism down a bit and it's back to opening up on the first tug.
Hotrodboba400
Dec 10, 2019 07:07 PM
neilb
Sep 15, 2015 05:06 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
