Hood clearance, Who has made it work?
Old Aug 5, 2008 | 04:36 PM
DirtyCanadian's Avatar
I have an 83 Trans Am side scoop ram air, i want to keep my stock hood, i have a performer intake and just bought holley 650 cfm dp mech secondary street hp, with 3/4" adapter plate, i bought an air cleaner that has a deep dish to fit over the carb and am going with a 2.3" wide by 14" o.d k&n filter (on order), has anyone made this work before?
Old Aug 5, 2008 | 04:40 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: Hood clearance, Who has made it work?
your going to need the drop filter plate on the bottom instead of the regular one the hood should close than i have the extreme k&n filter with the same detentions and mine fit with the stock hood
Old Aug 5, 2008 | 06:07 PM
i got the drop filter plate and a recessed top plate just waiting on 2.3" kn filter
Old Aug 5, 2008 | 06:23 PM
skinny z's Avatar
I use a 14x3 open element with a Moroso lid and dropped base.
Sits on a Holley carb with an RPM Air Gap. There is zero hood clearence. In fact the top of the filter housing rubs on the hood and I'm using a glass hood from an 82 Z28 for maximum room.
A shorter element brings the filter lid too close to the choke horn.
Still looking for solutions.
Old Aug 5, 2008 | 11:50 PM
wow! you fit an air gap in there nice work i would try make sure it isnt bending anything though that must be a harsh fit, i dont require a choke so thats one less problem to deal with.
Old Aug 6, 2008 | 01:36 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I have a 82 firebird with a flat hood, performer intake, 1406 carb with a 1" carb spacer and a 14x3 with a drop filter plate, the hood closes but the top of the filter housing rubs on the hood
It should fit, you'll probably have 1/4" to 1/2" in between filter and the hood.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
