Subframe questions????
Old Sep 4, 2008 | 10:52 PM
elthomas's Avatar
Car: 1985 Camaro
Engine: 2.8l v6
Transmission: auto
please look at the picture and tell me if this part is still available? by the way this isn't my car, the panel on mine is no where near that bad.
Old Sep 4, 2008 | 11:51 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Subframe questions????
It would be called left core support reinforcement. It was discontinued around 1995 or so. you will need to get it from a junkyard. Its really easy, I get them all the time....
Old Sep 4, 2008 | 11:57 PM
Where are you. Maybe I could send you one.
Old Sep 5, 2008 | 02:32 PM
elthomas's Avatar
Car: 1985 Camaro
Engine: 2.8l v6
Transmission: auto
i'm in North Carolina, i will take a picture of mine to see what you think of it.
Old Sep 5, 2008 | 05:18 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
i know this sounds bad but that is only because....it is! but mine was bent pretty bad when i first got my car and i was able to make it fairly straight by jacking/ hammering/ pulling. now it is covered by the battery and you can tell it is still bent but it doesnt draw attention to itself. i am not recomending this over the option of a replacement but if you are short on time and money it will work.
Old Sep 6, 2008 | 01:42 AM
If you can straighten it, go for it. If not pm me and I can get it for you. I am in AZ but the part is lightweight so shipping isnt too bad. Let me know. I have a few front clips laying around, so it's no problem...
Old Sep 6, 2008 | 03:20 AM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
has the other side been pulled in at all? Just because that is bent up a lot, that looks like it took a bloody good hit.
Old Sep 6, 2008 | 07:00 AM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
if yours is bent even half as bad as the one in the picture then you might have to have a body shop straighten the subframe for you.
Old Sep 6, 2008 | 09:38 AM
elthomas's Avatar
Car: 1985 Camaro
Engine: 2.8l v6
Transmission: auto
Here are the pictures of mine, tell me what you think. the first one is the front, the second one is the back side.
Attached Thumbnails Subframe questions????-cimg0653b.jpg   Subframe questions????-cimg0655b.jpg
Old Sep 13, 2008 | 07:14 PM
I dont think I would try to straighten that out... It looks like somebody already tried to. PM sent.
Old Sep 13, 2008 | 07:57 PM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
i think you could get it a lot more straight then it is but it would take a while and no matter how much time you put in to it, it will not be perfect. so if you want it good from far but far from good, fix what you have. if you have the time and money and want it to look better, fix it!
Old Sep 13, 2008 | 08:38 PM
icebird84's Avatar
Car: workcar Legacy Cruising 84 trans am
Engine: Ls1 99 corvette
Transmission: update working to get a T56
Axle/Gears: 2004 GTO IRS
maby here
http://www.autobodypartsonline.com/c...ts_search.html
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
