Stock Fiberglass TA hood???
Old Sep 18, 2008 | 05:33 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Anyone know where I can get one?
VFN only lists firebird and formula hoods.
ASCD is no help either.
Every site I check pretty much only carries RA hoods. That's not what i'm looking to get.
Would somebody care to share some info?
Old Sep 18, 2008 | 06:26 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: Stock Fiberglass TA hood???
do you mean a fiberglass hood that looks like the 85 and up T/A hood with the 4 vents? I've never seen one like that for sale. The best you can probably do is get a flat one and cut into it for the vents. Beware that it's very tough to get an aftermarket fiberglass hood to fit as well as a stock steel hood does. I was pretty disappointed with the fit of a Ram Air hood that I bought.
Old Sep 18, 2008 | 07:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
ive never seen one either, like said above, you will most likely have to buy a regular one and fit the vents
Old Sep 18, 2008 | 08:25 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
This blows. Yeah, I want a stock TA hood in fiberglass with the 4 vents. I want to replace my heavy steel one.
The RA hoods just aren't quite doing it for me.
Old Sep 20, 2008 | 07:31 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Nobody knows of anything? A rumor? Whisper? Possibility? Shred? Twinkle? Nuance?
Hmm.
Old Sep 20, 2008 | 02:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
http://www.showcars-bodyparts.com/firebird8292.html
Get a stock fibreglass hood and cut the holes for the vents.
To easy to put in the vents, why no one ever made one.
Old Sep 20, 2008 | 06:46 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Yeah, you just get the flat hood and cut for the vents. It's a pain, but if you do it right, it looks good. Fiberglass bolt on hoods arent much lighter by the way. (Maybe 8 pounds difference)
Old Sep 20, 2008 | 07:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the vents are not that simple to put in, cutting a hole and popping them in wont work.
they sit recessed, so they are flush with the surface of the hood. You will have to do some fiberglassing to the underside of the hood to mount them. Not a huge deal if you know what you are doing, but far from just cutting hole.
the side louvers actually snap in, so not sure how you would do that with fiberglass, unless you just slathered them up with resin and "glued" them to the hood
Old Sep 20, 2008 | 07:37 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Smart person would cut outside the vents, that way all you need is a square hole. No need to reinvent the wheel making a recess lip and such
Though you will have to glass them in on the under side and smooth it out on top. But when you deal with glass parts there is always finish work to be done.
Old Sep 20, 2008 | 07:51 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Im going to be doing something similar, Gett the vents cut out of a steel hood but they won't be going into a hood.
The front nose vents will be going into my A-pilers.
Dunno what to do with the smaller ones up farther.
Why? Air flow, two widows down isn't enough to make air flow well through the car. Don't have AC and often its hotter in the car then outside..
Not gonna do T-tops but need a way to get air to flow like 4 windows down.
I do have a notch back on [see sig] and a friend suggested a custom window like a truck with a sliding window but thats to hookey.
Old Sep 21, 2008 | 07:13 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Wait a second. I thought the fiberglass hoods were around 20 lbs. I never weighed my stocker but it sure feels heavyier than say 28lbs.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Randomtask2
Aug 13, 2015 01:57 AM
bryan623
Aug 10, 2015 11:33 AM
