What to d with Rust
Old Oct 3, 2008 | 04:11 PM
Emmaro's Avatar
What to d with Rust
Okay I have recently bought a 91 RS. The problem is, the guy we purchased it from bought it from a northern state and has rust holes in the hatch and under the rear bumper. I am new to working on cars so I am not sure what to do about this. I will post up some pictures when I get a chance to take them. Keep in mind though, I bought the car for $800.
Old Oct 3, 2008 | 11:52 PM
devilscamaro's Avatar
Re: What to d with Rust
All depends on the rust each situation is unique some times its as simple as sanding the paint off then grinding the rust till its gone primer bondo and primer again.
I like to cut the rust out and weld some new steel in when ever i can, i'm not a big fan of fillers but some times you have to.
I'm no expert but post a few pics and i'll help to the best of my knowledge.
Old Oct 4, 2008 | 04:06 PM
51F1's Avatar
Car: 1991 GTA,1951 ford f1 pickup
Axle/Gears: 3.42 10-bolt
I would sand blast instead of grinding only because I think its easier to get all the rust out of the surface than it would be to grind out possibly causing more damage. As long as there isnt a hole sand blast or grind, then self etching primer , bondo or fiberglass body filler, then primer again with a quaility primer
Old Oct 4, 2008 | 05:59 PM
I agree sand blasting would be a better idea then grinding/sanding the rust off but not many people have sand blasters and just about every one who does what we do has a grinder/dremel/sander, in the end all that matters is you get it down to bare steel no rust what so ever and protect it with a good primer.
Old Oct 5, 2008 | 11:49 PM
Emmaro's Avatar
The only problem is, there are holes. I would say anywhere from quarter sized, to golf ball sized and I am sure I will have the replace the rust areas. The hatch is my main concern, since when it is opened, the spots are noticable. And I think the only thing to be done is to grind/sand out the holes to try and make it look neater. I will try my hardest to get the pictures. I am not good at photography so I am waiting for my Fiance to take them.
Old Oct 6, 2008 | 12:01 AM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
I'll get some pics of it up sometime tommorow afternoon. It's not as bad as she thinks it is, it's not causing any problems, besides appearance when the hatch is open.
Old Oct 6, 2008 | 11:43 AM
Sounds like you have no choice but to get rid of the rust and weld some new steel, if you cant weld new steel in getting rid of the rust and protecting the area with a good primer is better then just leaving the rust there.
Old Oct 7, 2008 | 12:15 AM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
I have some nice hatches laying around here. Perfect shape with no rust or problems (Arizona cars) I have the wing style, IROC style or just plain.
Also I have some nice tail panels I could cut out for you
Old Oct 7, 2008 | 03:28 AM
Car: '86 Trans Am
Engine: 305 H.O.
Interesting. If you have any rs hatches, factory red, we may be interested.
Pics coming soon.
Old Oct 7, 2008 | 11:01 AM
Car: 1989 IROC
Engine: 305TPI
The only red one I have is off of a '88 sport coupe so it has the mounts for the small wing. The mounts similar to me as the '91-'92 F-40 style wing but I don't know if they are the same.
Besides the fading of the paint it looks to be in perfect shape.
Attached Thumbnails What to d with Rust-red1.jpg   What to d with Rust-reddy.jpg
Old Oct 7, 2008 | 11:14 AM
Car: 1989 IROC
Engine: 305TPI
Old Oct 7, 2008 | 12:02 PM
Car: '86 Trans Am
Engine: 305 H.O.
I would prefer to stay original with her car other than aftermarket mods. So if you get ahold of a 91 rs hatch, red, let us know.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
