universal gas cap
Old Oct 16, 2008 | 10:59 PM
ecdpres1's Avatar
universal gas cap
hello i am new here i recently aquired a 1988 trans am gta with 5.7L engine i had to put a fuel pump in the car to get it to run but now the filler neck is messed up and the stock cap doesn't fit correctly anymore i was wondering if there is a universal cap out there somewhere that would help me with this problem. the stock cap when on the car tends to leak a little bit of fuel down the inside of the rear fender and im worried that it may cause a problem if i continue to drive it like that...
thanks in advance
ecdpres1
Old Oct 16, 2008 | 11:14 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: universal gas cap
how did you mes up the fuel neck?
Old Oct 17, 2008 | 07:40 AM
kcb37's Avatar
If the fuel neck it messed up then you won't be able to buy a gas cap to fix it.
If the gas cap is bad yet.
Sounds like you need a new filler neck.
Old Oct 17, 2008 | 10:38 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
My filler neck eats gas caps. Every three or four months I have to replace my gas cap because it just won't screw in anymore. Try getting another one. I think they're only a couple of bucks.
Old Oct 17, 2008 | 04:35 PM
ecdpres1's Avatar
well thank you to everyone that has posted but i figured out the problem and got it fixed. in answer to how did i mess up the neck well i put the tank back in the wrong way and it hit the frame instead of going thru the frame and cause the filler neck to go out of round but what i did was too a pair of channel locks and squeezed it back until i could get the cap to screw in all the way so yeah the problem is fixed no longer do i have a leak out of my fuel cap. car just needs a tune up now and it will run 100%
again thank you to all who posted to either try to help me or ask me questions i appreciate it alot
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
