Door Sag, Cheap Solution?
Old Nov 5, 2008 | 09:04 AM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
Hey Everyone, My driver side door sags, I know a lot of people on these boards are saying buy an upper hinge kit, so I was looking around and found this on summit racing.
Dorman 703-266 - Door Hinge Pin and Bushings, GM, Kit
When you goto the application tab, and narrow it down, it says its for the front upper hinge, I was wondering if this really is what i need? if so $2.95 seems like a pretty awesome price.. or am I just getting a little too over excited?
can anyone verify this for me? wether or not I should go with this kit? i mean heck $3 bucks it might just be worth checking out huh?
Old Nov 5, 2008 | 09:08 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Re: Door Sag, Cheap Solution?
well... this is what i found out on my car. The reason the door sags is because the little wheels on the hinge have failed and the bushing in the middle is out so it is not tight against the ... tab (for lack of better word) thus it saugs to make contact. I ordered this part as well and it was not right. I ended up doing nothing for now until I can find the little wheels for the hinge. I do not want to have to replace the whole hinge but will if need be when I get the car painted.
Look at your hinge and try to determine if it is the pin or the wheels that have failed.
Old Nov 5, 2008 | 09:30 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
That $3 piece is a replacement lower hinge pin. If your play is in the upper hinge then the best solution is the upper hinge kit sold by TDS, a sponsor here. I've used it with success on one of my cars.
Old Nov 5, 2008 | 09:52 AM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
I got a kit from total auto off ebay... 58 bux plus shipping. Upper and lower hinge kit... looks real nice too. let me know if you want more info on it... i just got it in the mail the other day and it looks awesome.
and no, that $3.00 kit won't fix it. The upper hinge wears out and the holes enlarge slightly... the new kit comes with bushings for the upper hinge as well to take the slack.
Last edited by CamaroGuy71; Nov 5, 2008 at 09:54 AM. Reason: Automerged Doublepost
Old Nov 5, 2008 | 09:59 AM
hectre13's Avatar
Engine: HO 5.0
are you sure this is for the lower hinge? because when you goto summit racing and see what applications this is for, it specifically says front door upper hinge for 82-92 camaro.
Old Nov 5, 2008 | 10:25 AM
naf's Avatar
naf
Lower hinge. Look at your upper and lower hinges and you'll see the diff.
Old Nov 5, 2008 | 10:32 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
it may be the upper. the upper also has a pin but it is not usually where the problem comes from.
anyhow, does anyone know of a UPPER hinge kit that includes the little rollers that does not require removing and rewelding a new hinge in? I ordered a kit from Classic Industries for like 70 bucks and it was everything except what I needed. I can photo what I have and need if that would help but I would like to fix all my door issues...
all on drivers door only: sags, rattles real bad, lock wont lock with power lock button...
passenger door is like new perfect...
Old Nov 5, 2008 | 10:39 AM
naf's Avatar
naf
Nah, the upper doesn't have a continuous pin running through both hinge points. The kit from TDS can be installed without removing the hinge.
Don't know what your referring to with the 'little rollers'? Talking about the detent rollers adjacent to the lower hinge?
Old Nov 5, 2008 | 11:05 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
maybe you are right about the pin going all the way on the top i can't clearly remember but the rollers are the the little wheels that are about 1" in diameter that roll through the grooves when you open/close door to hold it half open and all the way open. my upper wheel is worn out so now the door sags... if i had my car here i would photo it but i don't. let me see if i can find a pic...
brb
Old Nov 5, 2008 | 11:12 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
ok not my door but this is the roller that i speak of. I know this is the bottom but there is one on the top too. mine is worn and makes the door sag... i need to replace the roller/bushing.
Old Nov 5, 2008 | 11:21 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
ok check this out...
http://images.google.com/imgres?imgu...%3D2%26hl%3Den
here is a better pic of the wheel on the upper hinge
my wheel is completely worn out so it isnt tight against the spring track or whatever its called...
Old Nov 5, 2008 | 11:39 AM
naf's Avatar
naf
Originally Posted by jrhaus76
ok check this out...here is a better pic of the wheel on the upper hinge
Nah, just so no one is confused that's another pic of the lower hinge.
Called a lower detent pin and roller kit on the TDS site:
http://www.top-downsolutions.com/ind...5ff80be5537fac
Old Nov 5, 2008 | 01:33 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
That roller won't make the door sag, it's not actually holding the weight of the door. All it does is give you the "stops" where the door will stay open, instead of just swinging in the breeze.
Old Nov 5, 2008 | 02:05 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
OK OK maybe that is a lower as well... whatever I am not near my car to go look. This is what I know... the wheel is worn out, on the top hinge, the pins and hinges themselves are fine. Maybe the door doesn't actually sag, it does sway in the breeze but now that I think of it, there isnt much, if any sag, just no ability to stay open on its own.
Old Nov 5, 2008 | 03:30 PM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
I have the same issue let me know what your solution was
Old Nov 5, 2008 | 04:18 PM
naf's Avatar
naf
Replace the detent pin and roller. Like $15 with shipping. Door doesn't even need to come loose. You can pop the spring out, replace the pin and roller then re-install the spring after tightening it down with some wire. Cut the wire loose after it's in and you're done.
Old Nov 5, 2008 | 05:03 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
awesome, where can i find that part?
Old Nov 5, 2008 | 05:25 PM
naf's Avatar
naf
lower detent pin and roller kit from Top Down Solutions (they're a board sponsor, although there may be other sources):
They also sell the upper hinge kits, same ones AndyZ28 makes.
Old Nov 5, 2008 | 05:49 PM
Stephen's Avatar
Car: 87 GTA
The $4 Autozone hinges are why my doors still sag....
A one door kit.......I can fix the lowers for $4 (both doors).....But it costs me another $92, to fix the uppers? What kinda profit margin is on those upper hinges?
Old Nov 5, 2008 | 06:50 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Good luck getting the pin out with the door still on.... In fact, good luck getting the pin out period. It is a major PITA.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
billybob6110
Sep 23, 2015 01:30 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
NiG
Sep 7, 2015 11:25 PM
