Which ground fx should I go with?
Old Nov 19, 2008 | 09:10 AM
fearthisinc's Avatar
i have a 87 IROC that has the factory groun fx package.. i was thinking of swapping it out for the ones that have the vents.. my friend had them on his 91RS from factory.. not sure if i should stick with original or go with those.. what do you guys think?
Old Nov 20, 2008 | 07:56 PM
JAY92RSTPI's Avatar
Car: 92 camaro rs tpi
Transmission: 700r
Axle/Gears: dunno neva checked
Re: Which ground fx should I go with?
go with the areo ones i love mines until this lil kid hit the front but know iam trying to get them there hard to find
Old Nov 21, 2008 | 05:20 PM
if they have a crack in them are they hard to repair? i am looking at 2 camaros in my area to use as donor cars.. both have good parts that i could use and i would only need to spend like 1500 for both cars.. anywya just wondering if once they are cracked it hard to repair or if it is something simple for a body shop to do.. thanks
Old Nov 21, 2008 | 09:48 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
They are (according to GM) a better product because they are supposed to allow more air to cool the brakes To me they look the same and if you do change them you will need to get the different mounts from the doner car, they are NOT a direct swap.
Old Nov 23, 2008 | 04:58 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
hmm they are supposed to cool the brakes? the vents are in front of the tires tho
Old Nov 23, 2008 | 06:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
[QUOTE=fearthisinc;3953098i was thinking of swapping it out for the ones that have the vents... not sure if i should stick with original or go with those.. what do you guys think?[/QUOTE]
I think you should chose what you like--screw us.
JamesC
Old Nov 23, 2008 | 06:56 PM
xNJ92RSx's Avatar
Car: 1992 rs
I have them, but I have a 92 so I never did any swapping, I dont see how they cool the breaks tho...............They do look awesome tho
Old Nov 23, 2008 | 07:20 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have an 88 s/c , i like the g.f.x. i have . i also like the 91-92 , but not enough to change them . the " scoops " are non-functional , but they look cool . do what you like , it is your car after all . i feel there are a lot of other things you could to improve appearence . good luck .
Old Nov 23, 2008 | 08:16 PM
JamesC's Avatar
Hey, Uncle,
I'm shocked that your eyesight, at your advanced stay on the planet, is good enough to recognize a difference !
JamesC
Old Nov 23, 2008 | 09:07 PM
UNCLE TOM's Avatar
Originally Posted by JamesC
Hey, Uncle,
JamesC
i " WILL " get you back JamesC , us old pharts need to stick together . i will still get you back , watch your " 6 " . check my eng. swap thoughts .
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
