Just a little rust....
Old Nov 23, 2008 | 10:09 AM
creature fiend's Avatar
WTF
As you can see, some major rust. I have no idea what to do, or what shop to take it to. And I could use some help...
Old Nov 23, 2008 | 10:31 AM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Re: Just a little rust....
WOW Never seen rust there on a thirdgen. If you found rust there, Imagine where else it could be hiding.. :-/
Old Nov 23, 2008 | 10:37 AM
^ that's what im afraid of....: (
Old Nov 23, 2008 | 10:52 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I have never seen a pillar rusted that bad....did you just buy this car?
Old Nov 23, 2008 | 11:31 AM
yes, about a month ago, just now was able to take some pictures
Old Nov 23, 2008 | 11:44 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i personally would go over the rest of the car first, before doing anything.
Pull the carpet, get it on a lift and check out the underside, check the bottoms of the doors.
if everything else checks out and is fine or workable, then look into repairing this.
I would assume the windsheild would have to be removed, and the pillar rebuilt. A competent autobody should be able to rebuild it, id dont know how hard it would be to cut that while part from a doner and have it patched in?
it almost looks like somebody cut the metal out?
Old Nov 23, 2008 | 12:19 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
If it's just the outer part and it hasn't worked it's way into the inner portions of the pillar then a repair would be fairly simple. I'd be interested to know what the rest of the car looks like, rust wise.
Old Nov 23, 2008 | 12:26 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Holy smokes!! I have never seen that much rust on the a-pillar before!
I could probably cut you an a-pillar out, if need be...
Old Nov 23, 2008 | 03:50 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
why did you buy that?
Old Nov 23, 2008 | 05:42 PM
When I looked at it, it was dark, and the guy had it covered with red duct tape so it blended in.
...., so, how much do you estimate it would cost to have it repaired?
Old Nov 23, 2008 | 05:58 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
duct tape, of course! imagine the money i couldn't saved when fixing all the rust on my car it almost looks like its been cut out and ready to be fixed before or is that just me?
Old Nov 23, 2008 | 07:39 PM
Kevin84Z28's Avatar
Unless you know someone in the autobody business that will take it on as a project, I would assume that it could easily run several thousand dollars. More than you probably bought the car for I'm assuming. It's a major structural component of the vehicle. I'll bet there are alot of guys on this site that would (and probably could) strap that job on. But if it were me I would sell, sell, sell...You'll take a hit, but in the end it will be less of a loss than if you pay to have it fixed. How much did you pay.?..don't be shy.
Yeah, looks like someone had a plan. They were probably going to just putty it up with bondo and paint. The real way to do that job would be to cut that post out.
Last edited by Kevin84Z28; Nov 23, 2008 at 07:41 PM. Reason: Automerged Doublepost
Old Nov 23, 2008 | 07:45 PM
Kevin84Z28's Avatar
Post up some more pictures of the car... some interiors too. Is it worth fixing?
Old Nov 23, 2008 | 07:51 PM
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
Thats a really big job. some one has cut that out for sure. take it to a shop and get some estimates.
Old Nov 23, 2008 | 08:18 PM
cost $1100...
Old Nov 23, 2008 | 08:53 PM
Car: 86 T/A
Engine: 5.0 TPI
I don't think that would be much of a job really. Pop the glass out and find a pillar to rob parts off of. If the inner structure isn't rusted thru you could clean it up and just replace the outer piece. Paint would be the killer. If you just spray the repaired part and don't worry about the roof it wouldn't be much. It's the rest of the car you need to worry about. If the rest is as bad as this, repair it with duct tape like the last guy and sell it... in the dark.
Old Nov 23, 2008 | 09:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Originally Posted by Kevin84Z28
Unless you know someone in the autobody business that will take it on as a project, I would assume that it could easily run several thousand dollars. .
no offence, but that seems waaaaay high. They are not rebuilding the whole car here. So long as the damage is just what we are seeing and does not extend into the car or into the firewall/fender area i dont see it costing that much.
*edit*
well, the more i think about it, you would need to pull the windsheild, the weather stripping around the door, probably the t-top seal as well. It could be pricey, and then paint ect. Maybe bring it to a shop and see what they tell you? Or just go the duct tape route a little longer.....
Old Nov 24, 2008 | 12:45 AM
Kevin84Z28's Avatar
Looks like you have a base model Camaro. I would really think hard about sinking any real money into getting that fixed.
Old Nov 24, 2008 | 07:47 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Ouch yeah that's scary...but it looks like the inside of the pillar is clean. The only way is, as said previously, to remove the windshield, drill the spot welds, pull out the rusted section and replace it with a part from from a donor car. If you can weld, have some tools or an access to tools (primer, grinder, spot weld cutter) and have a place to store the car for some time, it should be allright. I would add bracing while repairing this.
Also, and very important, check for other rust holes. I would remove the fender, pull the carpet to see the floors and take a look the water drain under the cowl panel.
Do you have a picture of how it looked like before you removed the tape ? I might be about to buy a car that has paint bubbling at the bottom of both A-pillars, it looks solid on the one I saw.
Old Nov 24, 2008 | 02:52 PM
Derth Deboblo's Avatar
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
Wow......just strip the thing for parts. There is really no point fixing a 3rd gen that rusty (especially one that bad). Hell look in the 2nd pic, see the spray foam?! I bet if you take off that a pillar trim it's rusted. Remember, the rust free cars are still out there.
Old Nov 24, 2008 | 03:36 PM
sap's Avatar
sap
Car: 1986 IROC Z
I couldn't believe it when I noticed a little patch starting to bubble up on that pillar on my car, it's gotta be the easiest place on the car to keep dry, painted, and salt-free
Luckily it was also easy to sand down
Old Nov 25, 2008 | 10:52 PM
allenfre's Avatar
WTF
Holy cow! That rust is so little that it almost shrink the metal to death. If this rust looks terrible, I strongly believe that there are still somewhere lurking
rv1890
Northern California
Dec 15, 2010 10:22 PM
meangreen92
Jul 26, 2009 11:46 PM
brewer
Sep 14, 2005 05:03 AM
waltersb
Oct 6, 2003 08:23 PM
r90camarors
Feb 20, 2002 11:42 PM
