My ground up (Start to finish) thread
Old Dec 29, 2008 | 09:35 PM
  #51
Bear8976's Avatar
Re: My ground up (Start to finish) thread
I just wanted to let you know, as all the others have said, you are doing an Awesome job on this. Do you work in a Body shop, or Machine shop with some of the skills you've shown in fabricating pieces?
Old Dec 29, 2008 | 11:08 PM
  #52
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Thanks! no i dont work in a body shop or any machine shop
nor any flied related to cars.
Old Jan 21, 2009 | 08:42 PM
  #53
FueledSoul's Avatar
Heres what i put off till about everything else was done.
this was probably the worse of the car. basically from the looks of it water, sand, road grim etc. might have got into some of the wheel well seems and adventively rotted lucky it only went as far a the lip. so i had to cut it all out and make my own backing and a peace to reconnect the lip. it took some time since i don't have any body tools or srinkers or stretchers just the old hammer and vice. heres some pics
Old Jan 22, 2009 | 10:39 PM
  #54
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
I have to do the same thing in the same exact spot on my car, must be a common rust spot. But I have more rust under there then you. You gave me a good idea how to approach mine. Thank you!
Old Jan 23, 2009 | 01:24 AM
  #55
FueledSoul's Avatar
Glade i could help someone. i still have to go over it sand it then re-coat it
Old Jan 23, 2009 | 01:34 AM
  #56
FueledSoul's Avatar
Iv been using these old rims from some 70s truck anytime iv needed or wated to keep the car pre-loaded and be able to work under it. But i needed to gain a some more room so i used some 4x4 and 2x4s to get the car up higher so i can have enough room to coat the underside of the car. i ran out of screws tonight i need to put 2 more 2x4 side peaces on each. the 2x4s have a lip to keep the rims kinda boxed in and for safety even though they will probably never side. because the cars going up higher its going to be hard to try and squeeze these rims up on the front with the car unloaded so im going to probably have to make a brace that will hold the a-arms up and keep the front preloaded while i jack up on the brace... heres some pics...
Old Jan 30, 2009 | 08:25 PM
  #57
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
Impressive work man. I'm subscribing for sure, can't wait to see how this all turns out. Please keep us updated.
Old Jan 31, 2009 | 09:35 PM
  #58
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Car looks like its coming out great..very professional rebuild.....for my 2 cents i'd say put the roll cage in....i have a 6 point in my 87......it's abolt in cage.....i also welded extra flat plats on to the top of my subframe connectors to allow the bolts from the rollcage to tie into that as well.......really stiffined up the car.. handels better and rides better too......allot less chasis flexing......keep up the picts!
Old Feb 3, 2009 | 08:08 PM
  #59
FueledSoul's Avatar
finally got around to getting the car up higher with everything still pre-loaded in some spots i have over 20"+ of head room underneath the car. . .
Still don't know if im going to use this stuff
Old Feb 10, 2009 | 12:29 AM
  #60
FlamedROC's Avatar
Car: 1989 IROC-Z
I will take the roll bar
Old Feb 10, 2009 | 01:39 AM
  #61
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
hey fueled soul, cant believe im just now running across this thread.. how much did you spend on all your suspension stuff minus the 9-bolt?
Old Feb 10, 2009 | 10:42 AM
  #62
fryer1979's Avatar
Engine: 350; none
I am interested in the STB should you decide not to use it. Feel free to contact me via PM.
Old Feb 10, 2009 | 11:03 AM
  #63
watson90z's Avatar
Car: 1990 iroc-z
Engine: 350 tpi
Axle/Gears: 3.23 posi
dude beautiful work i just started stripping my iroc and reading this thread gave me alot of ideas how to do my front suspension and rust resto thanks!!!
Old Feb 11, 2009 | 11:25 PM
  #64
FueledSoul's Avatar
hmmm. . . i will get back to you on that. If i got sometime all make a parts and price list
  #65
FueledSoul's Avatar
all keep that in mind
Old Feb 11, 2009 | 11:26 PM
  #66
FueledSoul's Avatar
Thanks, im glade this thread was some what helpful to you
Old Feb 11, 2009 | 11:28 PM
  #67
FueledSoul's Avatar
all probably be getting more stuff done on it this weekend all post some pics if i make a good amount of progress. . .
Old Feb 14, 2009 | 08:43 AM
  #68
fryer1979's Avatar
Engine: 350; none
Please do, but until then I'll be looking forward to new pics !
Old Feb 14, 2009 | 08:54 AM
  #69
Marc Brown's Avatar
That's awesome work ! looks great.... keep it up the good work!
Marc
Old Feb 16, 2009 | 04:06 PM
  #70
FueledSoul's Avatar
Old Feb 22, 2009 | 03:33 AM
  #71
FueledSoul's Avatar
So been playing around with sway bars obviously i cant test or get a feel for how i want the car to roll - understeer or oversteer but i at least have an idea instead of tossing on a 36mm / 25mm combo i think im going with a 34mm in the front and either a 23mm or 24mm in the rear to start out with. i think im scraping the jegsters and going to build my own tubular set of sub frames that would be far superior then anything offered on the market but we'll see. and if i do go that route id have to invests in a pipe notcher i kicked around the idea of fabbing up a set of lcas and a upper panhard bar since i know the exhauste is going to want to rest and bang against the stock one.
Old Feb 25, 2009 | 07:07 PM
  #72
fryer1979's Avatar
Engine: 350; none
Does anyone even make a replacement for the upper portion of the panhard rod? I was just thinking about your post and was trying to remember if I have ever seen one for sale anywhere. Sure would be nice to replace that stamped piece with either a boxed or tubular unit.
Old Feb 25, 2009 | 07:30 PM
  #73
92RSsleeper's Avatar
Car: 92 Camaro
Engine: 404 SBC
Transmission: The strongest stock T5 ever made
Axle/Gears: 3.73 w/Detriot Tru Trac Locker
subscribing....looks amazing so far!
Old Feb 26, 2009 | 09:51 PM
  #74
FueledSoul's Avatar
There are company's that make them. the upper bar ties in the left and right rear sub frame. i do need to clear my exhauste system besides adding some strength.
http://store.summitracing.com/partde...art=upi-2024-b
Old Feb 27, 2009 | 02:31 PM
  #75
fryer1979's Avatar
Engine: 350; none
Ah, yes I did see that, I guess it didn't click the first time through. Might not be too hard to make, but you would need to be able to make those bends and that would be pretty challenging. If you decide to give it a shot, I would love to see your photos. While I am a bit adventurous with my projects, that is a bit out of my skill level, I'll just roll with the kit.
Old Feb 27, 2009 | 09:39 PM
  #76
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Wow...awesome! Love to see such awesome transformation projects.
Keep it up!
Tommy
Old Mar 14, 2009 | 06:49 PM
  #77
FueledSoul's Avatar
Old Mar 19, 2009 | 07:51 PM
  #78
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
nice work man!
you are ahead of me in the project and the pics provide excellent motivation!
what headers are those?
Eric B
Old Mar 19, 2009 | 10:10 PM
  #79
madhatter's Avatar
very nice. reminds me of my ongoing build. keep up the good work
Old Mar 19, 2009 | 10:19 PM
  #80
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Looks really good, is that a factory painted swaybar or an aftermarket? The silver paint on the steering linkages looks good, did it come painted that color or was that a personal touch? The pic is a little blurry who makes those tie rod sleaves? They look really beefy, almost overkill.. I like it With all those poly bushings and the brand new tierod ends etc. it should handle like its on rails
Old Mar 23, 2009 | 12:45 AM
  #81
FueledSoul's Avatar
New Linkage Vs OEM stock
Been asked several times what im running so im posting a list of parts
Moog AMGK6145T $29.39
Summit SUM-TR-2227L $26.95
Summit SUM-TR-2226R $26.95
Energy Suspension 9-13101G $3.95
Edelbrock 5250 $37.95
PST GNSP00246 $47.00
PST GNSP00147D $47.00
http://store.summitracing.com/partde...5&autoview=sku
http://www.p-s-t.com/pc-521-21-chevr...o-1982-92.aspx
http://www.p-s-t.com/pc-4174-33-chev...o-1967-92.aspx
Old Mar 23, 2009 | 01:10 AM
  #82
Ca[maro]88's Avatar
this is a much needed upgrade for me. im droppin my fron springs an inch. need to get new struts obviosuly, what kind of struts do i need? can i get stock replacement struts or do i need somethin different..
Old Jul 23, 2009 | 11:13 PM
  #83
FueledSoul's Avatar
I haven't updated this forever so here is whats going on.
I pulled my dash out to run a new harness. Name:  Picture265.jpg
you can read more about why i pulled it out on post #115 at this thread
https://www.thirdgen.org/forums/memb...y-start-3.html
just have a few more things to do then i can paint the firewall.
I also built my own sub frames after all. It took sometime to do but they turned out great.
more pics and info can be found in this thread on my sub frames
https://www.thirdgen.org/forums/fabr...al-design.html
Old Jul 23, 2009 | 11:14 PM
  #84
FueledSoul's Avatar
I hand scraped and whipped most of the old undercoating and over spray and fixed a lot of small areas. i power washed and cleaned the entire underside. i pulled the rear end back out. It took forever to get to this point if i had to do it over id just build my own chassis and mount the body. Working on the top and bottom floor boards was more work then i anticipated and has eaten up about a year and a half of car down time but it needed to be done. the underside is in primmer i should have a new rubberized coating on the bottom by this weekend along with the rear end and more goodies back in. I would love to have a nice smooth painted underside but the amount of time require to take all that rubber coating off that one of the previous owners put on would be over to whelming and to time consuming to the leave that id want to take it too. this car is going to be driven and raced so the re-coating it doesn't make me feel so upset.
Old Jul 23, 2009 | 11:39 PM
  #85
houston_boss's Avatar
Car: 1986 IROC-Z
Engine: 305 TPI - 350 in the works!
Wow! Looks like it's goin great. Keep up the good work.
Old Jul 24, 2009 | 09:30 AM
  #86
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
great work , and nice sfc's. cant wait to see the final result
Old Jul 24, 2009 | 03:16 PM
  #87
FlamedROC's Avatar
Car: 1989 IROC-Z
Nice progress!
Old Jul 24, 2009 | 03:26 PM
  #88
MaDeNMiAMi305's Avatar
Car: 92 CaMaRo RS
Engine: CARBED 350 5.7
very nice! nice choice of products!
Old Jul 24, 2009 | 03:44 PM
  #89
DanTheAngry's Avatar
Car: 87 Trans Am
Those SFC's look really sweet man good job.
Old Aug 2, 2009 | 11:54 AM
  #90
FueledSoul's Avatar
  #91
FueledSoul's Avatar
thanks
Old Aug 2, 2009 | 11:56 AM
  #92
FueledSoul's Avatar
Originally Posted by FlamedROC
Nice progress!
thanks
  #93
FueledSoul's Avatar
thanks
Old Aug 2, 2009 | 11:57 AM
  #94
FueledSoul's Avatar
Old Aug 2, 2009 | 12:02 PM
  #95
FueledSoul's Avatar
The entire undersides done. the rear ends in place i just need to torque everything to sepcs. im currently fabbing a upper panhard bar. everything looks great and im very happy with how the underside looks.
Old Aug 2, 2009 | 12:04 PM
  #96
FueledSoul's Avatar
getting the 24mm swaybar ready for primmer and paint
painted
Old Aug 2, 2009 | 12:06 PM
  #97
FueledSoul's Avatar
Old Aug 2, 2009 | 01:28 PM
  #98
Car: 87 Trans Am
Nice progress. I'll have to fab up an upper panhard bar too. I'm anxious to see what you come up with.
Old Aug 2, 2009 | 02:04 PM
  #99
Ca[maro]88's Avatar
you going with adjustable lca's or just runnin with the stock ones?
Old Aug 2, 2009 | 11:32 PM
  #100
FueledSoul's Avatar
Thanks.
I just started and i posted pics and info of it on the fabrication board
but all still post a pic of it here finished and installed
