Plastic piece below the battery tray
Old Dec 15, 2008 | 05:28 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Over the weekend I was cleaning and polishing the battery tray.There is 2 bolts on the bottom and when removed I heard something let go.I removed enough screws on the bottom panel to get a look (it's a ball shped black plastic piece held in place by the 2 bolts on top of the battery tray)....anyone know what this is and what function it performs?
Also, does anyone have a pic of the battery hold down mechanism, my battery just sits on top of tray and I would like to get the proper hold down unit (part #, etc.).
Old Dec 15, 2008 | 07:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Plastic piece below the battery tray
Sound like the vac ball on a Camaro (driver's side).
Battery hold down, again for a Camaro:
http://www.moderndaymuscle.com/inc/sdetail/112
JamesC
Old Dec 15, 2008 | 07:18 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
on mine one end fits into the slot on the lower side of the batters to hold it in place. does your batters have an indention at the side almost at the very bottom? if it does then the wedge/slot portion of the hold down fits over that and is there to stop any movement at all of the battery.
it might help to see what piece you are talking about as gm did not appear to do everything the same way with the same car. even the wiring color codes change from car to car. not model to model but from one car on the line to another car on the line.
but i went and looked and my piece has one bolt, is wedged shapen and fits into the slot at the bottom of the battery for the hold down. i think my 91 had the two *****, or it may have been my 87, now i cant remember.
hope that helps.
Old Dec 16, 2008 | 06:22 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
sounds like the holy "orb of power" to me lol
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
64goatman
Sep 9, 2015 01:09 PM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
