HATCH PULLDOWN PROBS AGAIN!
Old Dec 17, 2008 | 06:30 PM
Daapunk's Avatar
Car: 88" Trans am
Engine: 350 bored. 383 Stroker Kit
Transmission: Power Glide
Axle/Gears: 4:10
Hi guys, assembly has been working well but other night i popped it and opened it befor it came all the way up. now it will not pull back down. any help PLEASE its RAINING!!!! Things Ive done, disconnected ground, reconnected. pushed latch with fingers to try and trigger but nothing happens.
Old Dec 17, 2008 | 07:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: HATCH PULLDOWN PROBS AGAIN!
Them things work good or don't.
Id dump it for a manual one or get crafty.
I welded nuts to the slide part, held the hatch shut tight weith weight then put bolts into the nuts that screwed against the track. Holding it tight in that position. So it now works like a trunk on any old car.
If you are dying ot keep it electric, buy all new part, no refurbs stuff.
Old Dec 17, 2008 | 07:59 PM
Daapunk's Avatar
Car: 88" Trans am
Axle/Gears: 4:10
I did. this is brand new complete rebuilt assembly cost me 300.00. new guides new motor housing new motor new bushing. new reverse switch
Old Dec 17, 2008 | 08:51 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
does anyone sell a manual kit for the hatches?
Old Dec 17, 2008 | 08:57 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If everything is new it should work, track greased well???
dissconnect wiring and hot wire it to a battery to know 100% sure its powered well, if it still fails, bad parts.
Old Dec 17, 2008 | 09:02 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
NO kit that I know of, just gotta find used parts. Never seen one work that was manual, has springs or something. But the electric sucks n cost to much to fix. Though when it does work right its ok.
Old Dec 17, 2008 | 09:27 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
you know someone needs to make some brass gears for these things soon because all those plastic tree's are at risk.
Old Dec 17, 2008 | 09:54 PM
Daapunk's Avatar
Car: 88" Trans am
Axle/Gears: 4:10
yea mines new and was workin fine until i pulled it up by hand befor it came all the way to top and released. Does anyone know or have pictures of how there wires are hooked. I heard ground wire must be in right place for solenoid to work right bc the top part is seperated by the nylon guides or some jiberish.
Old Dec 17, 2008 | 10:31 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I have a 92 from what I hear its different but my ground was right next to it.
Old Dec 18, 2008 | 12:00 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well there ya go, probably screwed it up inside. They are fragiel inside.
How I ruined mine, hatch was froze shut from ice and I had to jerk it open, never worked right again and cost to much to replace the parts.
ALso ripped off the pass side door handle that night trying to get in.
Old Dec 18, 2008 | 09:40 AM
Daapunk's Avatar
Car: 88" Trans am
Axle/Gears: 4:10
Man i dont know. I didnt jerk it opened before the latch was loose, it just hadnt risin to top all the way to top i dont belieave.
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
punkmaster98
Sep 30, 2015 11:01 AM
formula00ra
Sep 28, 2015 11:50 AM
