Paint matching and HF spray gun
Old Feb 22, 2009 | 06:45 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I recently replaced my front bumper and would like to paint it to match the rest of the car. I called the auto body guy who did the car and he used Dupont black # 99. I read on here the Dupont is not good. Why?
Also, does any other maker, i.e. ppg, make a black that matches the Dupont #99? Don't want to totally different shades of black.
Also, I just want to paint and clear the bumper. Can I use the HF guns? I read that this is not the choice of guns, but I'm not going into the business...just would like to save the money from going to the body shop. Any Harbor Freight guns decent for the base coat and clear?
Lastly, what clear would you recommend?
Thanks.
Old Feb 22, 2009 | 08:17 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Re: Paint matching and HF spray gun
i dont know alot about painting but i know the guys that is going to be painting my car uses a cheap gun from harbor freight and swears by dupont paint... hope this helps....
Old Feb 22, 2009 | 08:25 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
never had a bad experience with dupont paints, I really like them. and I will never own a HF gun but it should work for what your doing. my first gun was a husky gravity fed HVLP gun, costed me 50 bucks at home depot. I'd recommend this gun, it was great to me.
Old Feb 22, 2009 | 08:29 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
I use the HF HVLP gun. I got it on sale for $9.99. If you know how to "tune" the gun, use the right needle, get the mixture right, and know how to spray it works great.
Sorry, I don't have any input on the DuPont paint, I use implement paint.
Old Feb 23, 2009 | 08:03 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
heres how you match black
first put like a cup of black in then here is the hard part
add some more black
reduce it and put it in the gun
Old Feb 23, 2009 | 12:15 PM
Car: 1982 Z-28
Engine: 383
Thank you everyone. I appreciate it all the inputs. So Dupont is not a bad paint. I didn't think so, but I was searching last night and it seemed alot of folks do not like Dupont.
Home Depot HVLP gun? Really? Worked well? I had their HVLP gun in my hand on Sat.
Fyrechn - how do you tune a gun? Like I mentioned..this is the first attempt for me. If I go to HF will they have the tuning products? How did you mix, 2:1 ratio? And did you thin it with Mineral Spirits? Also, when painting clears it's best to use a smaller nozzle, like 1.3MM? Do they sell seperate nozzles?
Old Feb 23, 2009 | 02:02 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
the home depot one came with a 1.4mm tip, this is good for basecoats and clears and if you know how to clean it well you can even get away with primer.
Old Feb 23, 2009 | 08:00 PM
Car: 1982 Z-28
Engine: 383
Tmic - went on your car domain...is that the home depot gun in the photos? Or was the gun used on the pics of the body parts in the body shop?
Old Feb 23, 2009 | 08:16 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I have the home depot gun, it has a white cup on it. then I have a Sata Jet NR2000 that has a metal cup.
Old Feb 23, 2009 | 09:29 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
I have a Sata Jet 3000 hvlp and its been a dang good gun.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 28, 2015 02:28 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
