Some more work done and more to come
Old Mar 27, 2009 | 02:42 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
well Last weekend I decided to paint the front bumper on the 86 Iroc and today my cowl scoop showed up. next is to attach it to the fiberglass hood. and after seeing a different post putting pins on it also .
Attached Thumbnails Some more work done and more to come-cowl-scoop-002.jpg   Some more work done and more to come-cowl-scoop-003.jpg
Old Mar 27, 2009 | 03:40 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: Some more work done and more to come
looks pretty good. wanna see how the hood comes along
Old Mar 27, 2009 | 09:23 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Did Some work tonight Measured it out placed the hood on. ground down the area and drilled and rivited it on. then rinsed it all back off. Now gonna let it dry over night . tomorrow i will glass the seams.
Attached Thumbnails Some more work done and more to come-cowl-scoop-006.jpg   Some more work done and more to come-cowl-scoop-029.jpg
Old Mar 27, 2009 | 09:59 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I was looking thru the pics i have of this build I figured you guys would get a kick out of seeing it at teh start of the build to now wow big change.
Attached Thumbnails Some more work done and more to come-1986-iroc-z-269   Some more work done and more to come-1986-iroc-z-268
Old Mar 29, 2009 | 03:36 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
For those of you have wanted to see the progress of installing a cowl hood scoop on a fiberglass hood here is some more progress. here's what i have done I am by no means a body man and Honestly I hate body work too dusty and I have to work twice as hard to get it right because of my lack of knowledge on the subject. But 500 for a cowl hood wasn't in my budget so getting a scoop for $58.00 was the next best thing even tho after i ordered the scoop i saw a 6 inch pin on for $125.00 but he never got back to me. anyways here's what i have done..
1, Measure to get the scoop centered and lined up where you want it .
2, mark where the scoop is and grind the paint off in the areajust around where the scoop fits
3, drilled 4 holes in each corner through the hood and scoop and rivet scoop to the hood.
4, then drilled holes every 2 inchs down both sides and the front edges and riveted the scoop totaly to the hood
5, layup a layer of fiberglass around the perimeter of the scoop attaching the scoop to the hood.
6, lay bondo over the seam feathering it out a few inchs extra and to gradually transition from the hoods height to the scoops lip height.
7, sand
8 bondo
9, sand
10, bondo
11, sand you get the idea for those of you that are good at body work you might be able to do it in less steps of bondo and sanding.
12, filler primer/sealer
SO far i have half of the scoop done in bondo and the other half is still in the fiberglass stage. i did that for picture purposes. here's the photos..
Attached Thumbnails Some more work done and more to come-cowl-scoop-039.jpg   Some more work done and more to come-cowl-scoop-037.jpg   Some more work done and more to come-cowl-scoop-041.jpg
Old Mar 29, 2009 | 04:02 PM
not to shabby my friend, looks pretty damn good actually!
Old Mar 29, 2009 | 04:45 PM
popballz's Avatar
Car: 89 firebird
looks like your doing a real good job, good work!
you gunna cut a hole under that cowl scoop?
Old Mar 29, 2009 | 09:58 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
there already is a hole under there the air cleaner sticks through the hood. the Big Block has a semi high rise intake on it.
Old Mar 30, 2009 | 08:52 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Well It moved under it's own power out of the garage and back in. and here is the hood. close to finished
Attached Thumbnails Some more work done and more to come-cowl-scoop-058.jpg   Some more work done and more to come-cowl-scoop-045.jpg
Old Mar 30, 2009 | 09:44 PM
nice work, that looks flawless! i see u filled in the cars stats, nice setup, is she stroked?
Old Mar 30, 2009 | 11:34 PM
p100ki's Avatar
Why not buy an actual one piece cowl hood? What you ended up with is ok i guess but it doesn't match the hood lines at all. Kind of the Corky life goes on version of a cowl hood. It's too high and narrow but your actual work putting it on is really nice.
Old Mar 31, 2009 | 12:39 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Nope the motor isn't stroked. all i know about the motor. I got it from a family friend. It use to be in his back halfed 75 vega and ran a best of 9.50 in the 1/4 It was pulled and became his backup motor. sat in a garage for many years. I picked it up in November for $2000.00. from what i was told it has 6500.00 in machine work done to it. the pistons are 11 to 1 and with the heads on the motor. it's ratio is now 13.5 to 1 the cam is a lunati thats spelled wrong. it has a torker intake and a 980 holley. the cam specs are ? I was told it's over 600 lift and over 300 duration. the setup that was in the vega was this motor a th400 with a 3500 stall and the gears were 4.56. the block is a 73 pass car block and the heads if I remember are 427 can't remember the year. I know on the heads it says Hipo cast into them. the cam is a solid lift and has roller rockers. I have put an MSD streetfire billit distributor accel v groove plugs.
as for the hood Like i had said I didn't have the budget to spend $500 on a cowl hood I have 5 kids to support and a wife and this car hobby. This scoop was $58.00 its 40 inchs at the base and 4 inch's tall and 24 inch's wide it was advertised as a 44 inch scoop I should have bought the 49 inch which would have given me the 45 inch's at the base not the 40 I ended up with. but Oh well it's not like i can drive this on the street anyways. here's a pic of the motor with the covers off
Casting Number off the block 3999289 454 1972-1979 Two-bolt
If i read it from another pic correctly
Attached Thumbnails Some more work done and more to come-1981-firebird-001.jpg   Some more work done and more to come-1981-firebird-005.jpg
Old Mar 31, 2009 | 01:20 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
why do paople nit pick about a cowl hood? id rather spend 60 bucks instead of 500 bucks anyday (which is why i did). just wanted to say thanks for all the pictures and stuff. i had a pretty good idea of how i wanted to do mine and your gave me more ideas and gives me something to look forward to
what size rivets did you use? i have a 5/8 head on my rivets, not sure if theyre to big or not.
Old Mar 31, 2009 | 09:08 AM
damn 2k for that!!?? thats a freakin steal! better beef up the rear end, an add some sfc's with that combo.
i lucked out with my hood, i got a brand new harwood 4in cowl for $150 and $70 in gas to pick it up. before i found that, i was gonna take this route and save a bit. i couldnt pass up the harwood tho.
btw p100ki shut ur pie hole, it looks fine.
Old Mar 31, 2009 | 11:19 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Thank you all I like to hear other's like what i did and if it helps someone do it for themselfs then it's even better. I like to help and if the instructions and photos help someone do there's then it is worth it. everyone has different tastes and to p100ki if he doesn't like it thats his taste and he isn't wrong for that I wouldn't have a gold car with black strips down the sides of my hood but thats his taste and he isn't wrong for it. as for my car man it has been fun it has been frustrating, I have laughed, gotton mad, gotton disappointed and all during the build. But it all goes away the first time you turn the key and it comes to life and moves under its own power. there is things that i still have to do Like the sfc change rebuild beef up the rear end and also have to finish welding one of the bars on the roll bar I ran out of wire. I will need to change to a 3500 stall in the trans it doesn't like to idle in gear wants to die. and of course tune But i can't do that until i get an exhaust on the car right now i am running the patriot shorty headers and it's loud and I have a feeling the neigbors are going to get upset soon. But i do hope everyone enjoys seeing a 3rd gen get saved from a field and rebuild. I have owned many over the years this is my first iroc and now my first big block.
Old Mar 31, 2009 | 11:49 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I forgot to say this isn't my only hot rod either. 2 years ago I bought a car that has had almost every part of it replaced. except the body fuel tank and lines and interior . granted it's not a 3rd gen and it almost blashamy to own both a 3rd gen camaro and Mustang It started out as a 2001 v6 automatic. it now has roush stage 3 springs adr 18x10 in the rear and 18x8 in the front spintech side exhaust an 8.8 rear with 3.55 gears a 2003 4.6 auto witha roush cai and a snyper tune it has roush gauge cluster floor mats toolbox in the trunk painted body color dash panels and door panels a gt scoop on the hood was added Roush stage 3 body kit and spoiler. Autometer gauges and pods Billet accents to the center console and custom graphics that i did myself. the body stripes honeycombed taillights and all roush graphics on the windows and wheels and trunk it had a red top battery. bfg 275/35/18 in the rear and 245/40/18 up front
Attached Thumbnails Some more work done and more to come-photo120.jpg   Some more work done and more to come-moved-014.jpg
Old Mar 31, 2009 | 11:54 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
hee's another pic at a show this was before the 4.6 conversion and the stage 3 springs.
Old Apr 2, 2009 | 01:04 AM
p100ki's Avatar
Like i said man, the work you put into it is great. Not my style but it suits it's purpose and i can definitely appreciate that. A shot out in the sun from a straighter angle would be a better picture i think. It's probably not as boxy in real life.
As far as not driving on the street you'd be surprised what you can drive on the street if you keep off the loud pedal. Fifteen years ago i daily drove a ten second Chevelle.
Old Apr 2, 2009 | 10:47 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
In Ga I have to pass emissions with it thats not gonna happen LOL
atleast for 3 more years i do
Old Apr 2, 2009 | 07:57 PM
p100ki's Avatar
Yep, i'm lucky with the no emission of safety tests.
Old Apr 4, 2009 | 08:04 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
GA is rough! in NH and PA our cars are exempt from emissions.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
