Power Window Motor Installation Headache #?????
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Finally got my industrial hand rivet tool and let me tell you. BIG difference and ease of installation. Of course the door had some hairline cracks that needed to be reaired where the old rivets were.
I read a thread here where it said to make it easier to remove the motor and the other junk to bend the metal. Well I did and it was a pin to get it back to what it was and to align to the tracks. But, with some carefull bending inside the door and cut wrists, knuckles and fingers, I got it. A friend did have to help with the rivet tool but that was easy as pie for them.
So if you don't have the right tool, don't bother or things will go bad fast. Worth the $150+ bucks for it. Especially since I am going to have to use it again to replace both door lock solenoids.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Power Window Motor Installation Headache #?????
I think I just used 3/16" bolts with nylocks... Why would you bother re-riveting it?
Car: 1987 Camaro LT
The general consensus from what i gathered was bolts may come loose. Mind you, nylocks can be good in lighter applications. But from my experiences, I found that re-riveting is quicker and a lot easier than using bolts.
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
I used bolts with threadlocker red on them....those biatches aint going anywhere..I also cut off a piece of metal off the door to make it easier to access the motor...so i basically left everything in tact with the regulator and removed the motor by itself...piece of cake..
Car: 92 RS
Engine: LO3, 305 TBI
Axle/Gears: stock 3rd gen, 2.73 ratio
Did mine with a $20 rivet gun frpm Harbor Freight, got some rivets from a friend at a glass shop. One thing to note, on a 92 at least, if you cut off the rivets and then remove the rear track from the door and the window, the regulator slides out with very little drama, and reinstalls decently as well. I tried the nut and bolt method on the left door, and could only get a couple of the bolts in, I'll be pulling the panel and riveting that one as well.
*note* Be sure the electrical connection on the new motor is oriented the same as the old one, it is indeed possible to install the assembly upside down....
Car: 1987 Camaro LT
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
I didn't cut any part of the door, and I didn't spend a ton of cash on some giant pop rivet gun. I did mine the easy way and it only took a few minutes on each door.
Here's the easy way:
https://www.thirdgen.org/forums/body...tall-easy.html
Car: 1987 Camaro LT
Well the rivet gun was $150. Didn't need to cut my door at all.
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
wish i had 150 for a rivet gun like that
Car: 1987 Camaro LT
I was able to use part of my tax refund to buy it. And I have used it for other things on my other cars too where it calls for a 1/4" rivet. Now it would be nice to have a good sized air compressor to use and air gun and rotate my tires more easily.
now that i got
, along with a bunch of other nice tool, but that was also when i was bringing in $2,400 a week too and i SURE dont get that now working for the man Thread
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
