Paint Strippers
Old Apr 15, 2009 | 11:42 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Paint Strippers
What paint stripper can I use that won't ruin bondo or other filler?
Old Apr 15, 2009 | 12:48 PM
matj1990's Avatar
Car: 83 firebird/camaro conversion
Engine: carbed 350 very mild build
Transmission: th350
Axle/Gears: 3.42 posi
Re: Paint Strippers
sand paper
Old Apr 15, 2009 | 12:54 PM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Re: Paint Strippers
X2 Sand Paper
Old Apr 15, 2009 | 12:57 PM
cali92RS's Avatar
Car: White KSwisses
Re: Paint Strippers
Originally Posted by matj1990
sand paper
LOL...
OK,
I will be a bit more specific.
Any chemical paint stripping agents that wont ruin the bondo.
Old Apr 15, 2009 | 02:04 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: Paint Strippers
.... melted sandpaper?
Old Apr 15, 2009 | 02:32 PM
matj1990's Avatar
Transmission: th350
Re: Paint Strippers
LOL...
OK,
dont think there is any
Old Apr 15, 2009 | 03:38 PM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
Re: Paint Strippers
if it was straight lacquer, you could use lac thinner and just work fast over the bondo areas...and more than likely be alright unless your bondo application is shoddy.
No chemical paint stripper is weak enough to not effect Bondo
Bondo is not to be used to FILL baseball sized dents. Personally, if I cant get a magnet to stick to the metalwork though the bondo, I dig it out and keep reworking the metal till I get it closer to 'right'
Dont use that glazing putty stuff thats to fill pinholes (icing) UNLESS it has a hardener you have to add (like bondo) the stuff without hardener is just the sludge from producing lacquers (like duplicolor). It'll shrink and fall out eventually
Old Apr 16, 2009 | 10:10 PM
Slouch's Avatar
Re: Paint Strippers
Fine grit walnut shell...
Old Apr 17, 2009 | 09:14 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Re: Paint Strippers
like the other guys said.....any chemical paint stripper wil also soften and eat bondo. If the paint is really soft and just pluggs up the sandpaper too much, try some NAPA brand water rinseable paint stripper....used a bunch of it this week on a rear bumper cover.....really cooks the paint off..........
Old Apr 19, 2009 | 12:29 AM
NatesZ/28's Avatar
Re: Paint Strippers
good tip, work fast on the plastics though as the stripper can leach out the petroleum distilates and cause your plastic to become brittle. It also might be sold as 'water soluable' or 'water borne' neither of which are water BASED or particularly friendly to you and yours...so be careful, even gentle solvents are still solvents
Old Apr 20, 2009 | 04:44 PM
Slouch's Avatar
Re: Paint Strippers
Or use a urethane paint stripper?... Does not cost that much and will save you a headache.
Hotrodboba400
Dec 10, 2019 07:07 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
