Outer window weather strip?
Old Apr 16, 2009 | 09:35 AM
slia67's Avatar
Does anyone know if there is a way to remove the outer window weather strip on a 92 'Bird w/o having to loosen the front window track? Thanks.
Old Apr 16, 2009 | 10:02 PM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
Re: Outer window weather strip?
are you talking about the rubber squeegee strip on the outside edge of the window? I think I took my INSIDE door pael off, put the window down and tipped the window to the inside and the rubber thing just clips in or might have a couple screws. I'll check my notes tomorrow for you
Old Apr 16, 2009 | 10:57 PM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
i just did that today, roll the window all the way down, take off the door panel, remove the 2 window bumpers that push the window towards the weatherstrip so you can pull the window all the way back towards you, take off the bolts holding the weatherstrip, if the window dosnt go down all the way take off the window triangle and that let my window go all the way down, then bolt on the new one
Old Apr 17, 2009 | 06:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/body...-shortcut.html
JamesC
Old Apr 17, 2009 | 10:26 AM
NatesZ/28's Avatar
nice job guys
Old Apr 20, 2009 | 02:38 PM
slia67's Avatar
Great info. Thanks.
jrdturbo
Mar 31, 2016 02:58 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
Nick McCardle
Sep 10, 2015 08:36 PM
blackandblue02
Sep 10, 2015 08:19 PM
