86 camaro (Ferrari)
Old May 5, 2009 | 12:49 AM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
86 camaro (Ferrari)
Anyone seen this? I believe its for sale on ebay. Or was.
Old May 5, 2009 | 12:50 AM
Car: 91 RS T-top
Re: 86 camaro (Ferrari)
Old May 5, 2009 | 03:00 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Never seen it before, and don't really like it, it just looks like an expensive body kit.
But, I love the idea of a STB like that. I'm going to save that pic...
Could you post a link to where you found this car, or give us more info?
Old May 5, 2009 | 09:05 AM
1Aauto's Avatar
Former Sponsor
As far as kits go (by the pics) the fit looks pretty good.
Old May 5, 2009 | 09:14 AM
87_Injected's Avatar
Car: 2010 2LT RS
That car looks good. Someone took alot of time and effort to make it look like that. Hell I'd drive it! I also like the fact that they used the IROC louvers on the rear lid.
Old May 5, 2009 | 09:27 AM
1Aauto's Avatar
Former Sponsor
Didn't even notice the louvers. It looks like whoever makes it,thought the kit out pretty well.I've seen some pretty bad fitting kits in my day.
Old May 5, 2009 | 09:36 AM
Stephen's Avatar
Car: 87 GTA
That is the cleanest Ferrari body kit conversion I've ever seen. From the outside (except for the IROC louvers) you'd never suspect it wasn't real (until the engine was started).
I'd drive it.
Old May 5, 2009 | 10:06 AM
Car: 91 RS T-top
This should get you to the car and there are a few more pics.
http://www.extremeauto1.com/detail-1...o-3239755.html
I like the idea of totally changing a cars looks but I dont think Id want to make it look like another car. I give the gut mad props. It must of took alot of work, I also like the louvers on the rear. Keeps some of the Iroc in it without it looking like it doesnt belong.
A++
Old May 5, 2009 | 11:00 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
That took some serious work, he even reshaped the pillars and check out those relocated HVAC controls
Old May 5, 2009 | 11:02 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I am impressed to be honest, seems like they got lazy around the headlights but did well otherwise.
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Looks to me like they used trans am front fenders but could be wrong. The job looks done well but not for me.
Old May 5, 2009 | 11:10 AM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
As far as kit cars go this one pretty bad, that is it wouldn't fool a Ferrari enthusiast more a second. However i do have to give the builder a world of credit as it looks like a lot of hard work. I would drive it !
-Z
Old May 5, 2009 | 01:41 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
that does have firebird fenders, hood and latch support. That also means the headlights had to be mounted lower than the original camaro ones. There is TONS of great fabrication and creativity in that car! I like it a lot!
Old May 5, 2009 | 02:02 PM
Stephen's Avatar
Car: 87 GTA
Nope....Look at the pic with the hood open. The fenders extend WAY too far forward to be Firebird fenders & I see no seam in any pic suggesting that they are simply an extended nose.
I think those are custom fenders & hood, since there are no flip up headlight doors left, nor do I see a seam when the hood is closed. And no, I seriously doubt they were just molded to the hood. That would be extremely difficult, since they aren't metal & couldn't just be welded in place a Firebird hood.
Old May 5, 2009 | 02:59 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
That's exactly what I thought the minute I looked at it.
Old May 5, 2009 | 04:11 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Yeah its hard to say. Someone could have easily welded in extensions to Firebird fenders. To me The Firebirds have a more rounded look and right above the front wheels and back it looks more loike a Firebird. So hard to tell.
Old May 5, 2009 | 05:33 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
That's the best looking set of stock Camaro tail lights that I've ever seen.
Old May 5, 2009 | 05:43 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
I'd rock it, clean conversion.
Old May 5, 2009 | 06:47 PM
Firebat's Avatar
The side marker are in the wrong spot for them to be firebird fenders. Might be firebird fender flares welded in, hard to tell what they did. Never saw a strut tower brace like that before.
Old May 5, 2009 | 07:07 PM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Thats one of the best looking kits Ive ever seen. They really spent alot of time doing it right--even the interior would fool an untrained eye. I would ride around in that ALL day long and Ill bet you very few people would realize its not a real ferrari.
Old May 5, 2009 | 07:11 PM
deadbird's Avatar
Engine: TPI 305/ v6
Probably what is making it look like the fenders are extended (aside from camera angle) is the fact the side markers have been moved back, closer to the wheel opening.
Pretty simple task, I would imagine ,if you have the skill to do what was done to the rest of the car to transform it.
As far as the headlight cutouts, making some sheetmetal fillers to weld in would be a a trivial task. IIRC, Redraif did the same to her car since she deleted the pop-ups on her 'bird.
If you look close towards the hood hinges (pic in link above), you can see where the stock bracing has been cut and removed from the hood leaving a fairly clean underside. I can only wonder if that would be n issue at speed though...
The reworked/covered stock console and air cleaner are pretty trick. Along with what appears to be a rotating license plate (pic in the link above)
Overall, the kit car isn't any longer than a stock f-body and is very nicely crafted..... except maybe the engine bay itself...
Old May 5, 2009 | 07:24 PM
deadbird's Avatar
Engine: TPI 305/ v6
double post
Old May 5, 2009 | 07:43 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
I would go back and make my case about them being firebird parts that were significantly modified, but Deadbird did it for me with excellent pictures for comparison :-) Notice in the pictures that the wheel well shape on the kit car is identical to that of the firebird fenders. For the filler panels over the pop-up headlights... i nearly did the same myself but ended up abandoning that project in favor of getting my car on the road to actually drive again sooner. I was going to weld in corners of a stock camaro hood that seemed to match the contour well enough for such a small section.
Old May 5, 2009 | 08:51 PM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
That's really cool.
Old May 5, 2009 | 09:25 PM
my89convert's Avatar
Car: 89 Camaro RS Convertible
Engine: 5.0 305 170HP stock
I wish I owned this sweet ride. I would like to know what a customization like this would cost.
Old May 5, 2009 | 10:06 PM
racerquinny's Avatar
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
id drive it, and scare some rice rockets. then tell them its a chevy....sort of.
Old May 14, 2009 | 09:20 PM
guy77's Avatar
your all wrong but thts ok. im the builders son . all the parts you see on this car is all hand fabricated its all metal no kit everything is hand made . those are camaro fenders extended with real (medal) and yes the marker lights were moved back. we sold this last year . took us 2 to 3 years to build and everything came out amazing . thanks for all the compliments .
Old May 14, 2009 | 09:56 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
very nice! a lot of fab work. looks great. gotta respect it.
deadbird's Avatar
Engine: TPI 305/ v6
I, personally, would be extremely interested in seeing some pictures of the build process. As I'm sure the rest of the people here would like to see as well.
Old May 14, 2009 | 10:01 PM
Ca[maro]88's Avatar
deadbird is correct. if you got pics, we would LOOOOOVE to see them.
Old May 14, 2009 | 10:59 PM
gon8go's Avatar
Car: 89 trans am ws6
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
I like the leather console and nice job on the kit but.....eeeeeeeeeeee heeeeee
heeeeeewwwwww!!!!!!!!
Old May 15, 2009 | 07:27 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
gon8go, you have to respect the craftsmanship and work that went into that car. If you saw it at a show in person and the owner was right there, would you go up to him and say the same thing you typed here? It's pretty disrespectful considering how much amazing work he put into the car.
And YES I want to see build pictures! Guy77, it's hard to believe those aren't modified firebird fenders considering the similarities in the wheel well shape and the top profile that were shown in comparison pictures by deadbird.
Old May 15, 2009 | 03:16 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
I LOVE the interior and sound system!!
Old May 15, 2009 | 04:20 PM
guy77's Avatar
those are camaro fenders i worked on them myself . but all the before pictures were took with a disposable camera srry but i have tons of pictures of the car from my house if u would like to see them.
Old May 15, 2009 | 04:32 PM
guy77's Avatar
http://s130.photobucket.com/albums/p...t=S7300997.flv
http://s130.photobucket.com/albums/p...t=S7300253.flv
http://s130.photobucket.com/albums/p...t=S7300256.flv
http://s130.photobucket.com/albums/p...t=S7300254.flv
Old May 15, 2009 | 04:42 PM
guy77's Avatar
theres 4 vids if u wanna whatch them
Old May 15, 2009 | 04:45 PM
guy77's Avatar
Old May 15, 2009 | 05:20 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I think I speak for everyone here when I saw "DUH!!"
Beautiful work! If you can get those pics scanned and posted, that'd be great!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
