headlight motor rebuild? yes or no?
Old May 7, 2009 | 08:39 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i had a headlight motor go bad on my 87 and was wondering if anyone had rebuilt one of these before? it looks pretty simple and the parts are dirt cheap on ebay... any comments would be great!
Old May 7, 2009 | 08:47 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: headlight motor rebuild? yes or no?
Get the rebuild kit from Lon at Top Down Solutions.
http://www.top-downsolutions.com
It's very straight-forward and easy. His kit comes with full instructions that are very helpful. The hardest part is pulling the brushes back to get the motor reassembled. It's a nice, easy job.
Old May 7, 2009 | 09:00 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
alright thanks man...my motors are still good its just the busings in the bottom that turned into a pile of dust so im just gonna do those til the motors die then ill attempt that.
Old May 7, 2009 | 09:22 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Yes, you just need new bushings and you'll be fine. We have bushings sets available on our website if you need them.
Old May 7, 2009 | 09:40 PM
gcgarner's Avatar
That kit is for the nylon bushings. Mine were crumbled in my driver's side. The rebuild kit made the job easy.
Old Oct 2, 2009 | 06:31 PM
SanFranCyco's Avatar
Car: 87 GTA
Engine: L98 5.7 24#inj,World hds,MSD,nosmog
Transmission: 700R4 truck clutches,Trans go shift
Axle/Gears: 10 bolt chevy 3.73 limited slip
Use dental floss. just put dental floss around the braided wire in a loop so you cann pull it out when done.do both sides then fit motor back and when the brushes clear pull it out.
Old Oct 4, 2009 | 11:35 AM
SlashXIII's Avatar
Car: '86 Trans Am
Transmission: Automatic
i didnt see any kits on that site foe an 86... where would i find one for that year?
Old Oct 4, 2009 | 01:14 PM
Former Sponsor
Car: Too many
The earlier style motors (82-86) don't use bushings so your motor would have some other problem. What problem do your motors have?
Old Oct 4, 2009 | 02:12 PM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
It wasn't too difficult? I'm probably going to have to fix mine, but I'm having difficulty with mine as well. They come up sometimes and most of the time...not. I hate having to crank them manually.
Old Oct 5, 2009 | 11:18 AM
1Aauto's Avatar
Former Sponsor
We carry new motor kits too for the 87-92,here's a link to them.
Trans AM headlight motor kits
Old Oct 11, 2009 | 11:49 AM
SlashXIII's Avatar
Car: '86 Trans Am
sorry it took so long to answer... I don't really know how the headlight motors work really... mine wont open or close automatically... i have to pop the hood and turn that **** once it starts getting dark... didnt have time to take them apart or anything, just thought i could rebuild them somehow...
Old Oct 11, 2009 | 12:19 PM
strc09's Avatar
Ouch...$436.90
Advance has reman motors for half that for the pair ($169.08). Are the ones sold thru 1A OEM motors or remans?
Is there a relay or module for the headlights like there is for the foglights?
Old Oct 15, 2009 | 12:30 AM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
I fixed both of mine with some air line hose. Found that fix on the Internet somewhere (they used a hot melt glue stick).
Basically what you do is remove the headlight motor from the assembly. Open motor up and the old pulverized bushing dust will just fall out (the only reason your headlights go up and down sometimes is because enough dust collected together to form a clump and raise the light).
Now cut 3 bits of air line (about 1/2" lengths if I remember). Pop those in to the little cutouts where the old bushings used to be and grease her up in there.
Reasemble and put it back on the light assembly. Job done (and it cost nothing).
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
fbirdroller
Sep 2, 2015 10:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
