How do I install RS grill to Iroc/Z28 Grill?
Old Jun 12, 2009 | 09:11 PM
BigLou907's Avatar
Car: Camaro RS
Transmission: Automatic
Axle/Gears: Not Posi :(
Hi, I just purchased a brand new grill for my 91 RS, and i was wondering how to install it. Its not a 91 or 92 grill it says CAMARO on the front instead or having the bow tie and I was wondering how to install it. I'm sure its easy, but I don't want to risk messing anything up on my car, so who wold know better then veterans who have done the mod before. Pics would be great, but any type of description would be a big help thanks!
Old Jun 12, 2009 | 09:16 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: How do I install RS grill to Iroc/Z28 Grill?
Physically it either fits or it doesn't, it is attached by a few screws possibly torx screws and should be remove it, install it. Am I missing something, are you trying to figure out how to fab it in there
Old Jun 12, 2009 | 09:20 PM
BigLou907's Avatar
Car: Camaro RS
Thanks for the response!
Naw, I'm not trying to fab anything, I just don't have the first clue about taking the old grill out, and installing this new one I just got lol
Old Jun 12, 2009 | 09:28 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Just look directly at the grille closely, you will see screws attaching it
Old Jun 12, 2009 | 09:31 PM
BigLou907's Avatar
Car: Camaro RS
lol no doubt! But do i have to go in through behind the original grill or does everthing thing disconnect from the front?
Old Jun 12, 2009 | 09:33 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
from the front.
BigLou907's Avatar
Car: Camaro RS
And will the same screws holding the old grill on work with the new grill?
Old Jun 12, 2009 | 09:41 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Remove the license plate and the other few torx or bolts. Reverse the process to put the other one on.It's been a couple years since I put mine together. Not hard realy.
Old Jun 12, 2009 | 09:45 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Yes. And your RS grille may have 3 screws through the front (under the louvers) holding the center section in. Your new grille probably has 4 screw holes in the sides of the center section (2 in each side), I used some drywall screws there for my grille.
Old Jun 12, 2009 | 09:58 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
a simple install . remove old grill , wash/clean areas behind grill . look at new grill , look old grill . install screws as needed for new grill . done with speed nuts . good luck .
Old Jun 15, 2009 | 04:42 PM
BigLou907's Avatar
Car: Camaro RS
Thanks for all ur input guys, you were all a big help, i got the grill on an it looks great i had to go under the car and remove a couple bolts from the air tunnel thing, then i could take a 4 screws that you cant get from the front, then i just put the new grill on changed some clips on the top, put in 4 new screws on the sides of the new grill and put the two screws on the top of the grill back on, screwed the bolts back in from the air tunnel thing an it looks great ill put pics up soon.
Thanks again.
Lou
Old May 23, 2012 | 11:14 PM
johnf123's Avatar
Car: 1992 RS vert
Engine: forged 383
Transmission: a busted one for now ;)
Axle/Gears: 4th gen 3.73
im doing this now, and NONE of my bolt holes fit from my old grille to my new..help?
Old May 26, 2012 | 06:06 PM
my82roc's Avatar
Car: 89 Iroc Convertible
The top ones along the back edge should be the same.You will have to drill the holes along the inside edges.
Frozer!!!
Jan 19, 2024 04:55 PM
69 Six Pack
Oct 5, 2015 07:51 PM
silverstang84
Exterior Parts Wanted
Sep 21, 2015 08:05 AM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
mustangman65_79
Aug 12, 2015 06:39 AM
